Home > Detailing & Car Cleaning > Snow foam lance prob |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Have you stripped it down & given it a good clean,also it could be the filter gauze that is blocked.Might be worth buying a new gauze first as they are cheap enough.what I do with mine every time I finish using it I unscrew the bottle with foam in it & put the pipe in a container with clean water & run that through the gun to keep the gauze clean. Andy.
Sat Jun 22 2019 7:40pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4815 |
I haven’t.
Sat Jun 22 2019 7:52pm |
Depends which lance you have. Andy.
Sat Jun 22 2019 8:24pm |
If it’s like this then here you are
Sat Jun 22 2019 8:26pm |
Thanks. I’ll check that video |
Sat Jun 22 2019 8:27pm |
& their is this one Andy,this is the lance I have
Sat Jun 22 2019 8:29pm |
Thanks guys |
Sat Jun 22 2019 10:59pm |
The tiny hole that the soap goes thru was blocked.
Sun Jun 23 2019 5:35pm |
