Home > Off Roading & Green Laning > Blimey, these cars are capable!! |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Having a nice day...
Sat Feb 09 2019 2:12pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Quick wipe with a old towel and that'll be good as new!
Sun Feb 10 2019 11:38am |
It came back scratched to and with a massive dent in the bonnet!
Sun Feb 10 2019 1:03pm |
Mine looked like that a few weeks ago when I was out feeding pheasants. Had to go across a wet field to get to some feeders. Absolutely caked in mud and the tyres looked like muddy doughnuts. It then rained overnight which got rid of most of the mud!
Sun Feb 10 2019 1:09pm |
The dent came from sliding into a tree (it jumped out of nowhere, honest!) It isn't creased, so might be retrievable.
Sun Feb 10 2019 1:24pm |
It is called super-extended mode and you can force the car into it but you would have to cross my palm with silver to get the secret out of me! there is a sensor under the car that will detect under car clearance and can extend the suspension a little bit more. If you have the DR pack on your TDv6 HSE there is rumoured to be another clever trick that the rear suspension can play to give a small amount more rear wheel articulation too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Feb 10 2019 5:43pm |
What ground clearance sensor is that then Tim, other than the four ride height sensors?
Sun Feb 10 2019 6:03pm |
Of you could look at the Land Rover Passion suspension ECU that i use
Sun Feb 10 2019 10:51pm |
Diversurfer Member Since: 24 Mar 2018 Location: Bragança Posts: 19 |
I there, would the "Foot on the brake pedal and hold the raise button for a few seconds and you can then get super extended mode" work if you don't bottom out first. I think the D3/4 can do this at anytime, would the RRS do the same? Cheers |
Sun Sep 15 2019 2:25pm |
I have the DR pack on mine. do you mind sharing! |
Sun Sep 15 2019 2:26pm |
No, the extended mode is not selectable without first grounding. Similarly, super extended mode (foot on brake etc) only becomes available once extended mode is active. This is the same as the Disco. You can buy kit that allows full height selection, and some forum members have done just that. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun Sep 15 2019 7:05pm |
People following me when I have been in Off-Road + 50mm (via the Easylift and the same height as extended mode) have commented that the [rear] wheels have started to 'tuck in' quite noticeably. |
Mon Sep 16 2019 6:57am |
Yes, the suspension geometry makes the camber change a lot as ride height changes. 2012 SDV6 - it's missing a couple of cylinders
Mon Sep 16 2019 7:53am |
A good justification for not changing ride-height when the car isn't moving and is on tarmac. If I am playing with the Easylift, I make sure the car is moving - even if it means forwards/reverse over a few metres. |
Mon Sep 16 2019 8:04am |
