Home > Technical > Lower Arms Price Supplied & Fitted? |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 |
Had some clunking on the NSF of late and assumed it was ARB bushes again. The car was just in the local indy for a service and I asked them to check while there, and they said it needed both lower arms.
Mon Oct 15 2018 7:42pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8869 |
Hypothetically one can remove the arm and just replace the bushes. Bushes are much cheaper than the whole arm, of course. The reality is that the bolts are usually seized in the bushes and the only practicable way to remove the arm is to cut it off. Going in with the intention of cutting and replacing will likely save time compared to trying to get it all undone - which could take some time and thus money. You can get lower arms for as little as £100 each from Advanced Factors, more if you want better/name items (LR items are about £250 each from AF, likely much more from a dealer. You need a bolt it too. AF will sell you a whole arm kit (pair of arms and the bolts).
Mon Oct 15 2018 8:54pm |
Is it a job simple enough it can be left to a regular all round garage or would an indy be preferable for any reason? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Tue Oct 16 2018 5:49am |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
I had both of my lower arms done a couple of weeks ago at my local indy. £650 all in for the arms with pre-installed heavy duty bushes. The standard bushes have liquid/gel in them, so wear quicker. The heavy duty ones are solid, so somewhat tougher- I was expecting more a little more noise from them, but car drives exactly as it did before, and without the clunking
Tue Oct 16 2018 11:32am |
I'd go down the indy route as they're likely to have done them before and know the tricks, where to cut them etc. 2012 SDV6 - it's missing a couple of cylinders
Tue Oct 16 2018 12:53pm |
Eek - I must do that again? Last time I had to have that done at the main stealers. Pairs of arms can be had from Fleabay for £120-£130 ish it seems. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car. Spiffing wheel centre caps available |
Tue Oct 16 2018 10:10pm |
I bought a pair of lower arms of ebay for £140 I think and it was £220 labour including 4 wheel alignment. Steve. |
Wed Oct 17 2018 4:26pm |
I do wonder how good an arm is at £70 a pop, but I guess if you're not keeping it for more than a year then they're ok. 2012 SDV6 - it's missing a couple of cylinders
Wed Oct 17 2018 7:37pm |
