Home > Maintenance & Modifications > TDV8 gearbox service kit advice
RRSV8
Hi guys
Need to service gearbox on my 2007 RRS TDV8
is it best to use the oem plastic filter/sump or metal sump conversion with separate filter
also i have leak on the mechatronic sleeve do i only need to change one seal or replace complete sleeve
where is best place to buy these parts ?
thanks
Post #565882 Wed Sep 26 2018 5:50pm
Disco_Mikey
Plastic sumps are superior to the metal ones, though harder to replace
Mechatronic sleeve is £9for a new part, just replace the whole thing Thumbs Up
Post #565889 Wed Sep 26 2018 7:24pm
well metal ones tend to leak and don't always have a drain plug.
plastic ones need the front cross member removing to refit. (old one is cut off if new metal one fitted)
Generally the whole sleeve is changed as they are only £10
Post #565890 Wed Sep 26 2018 7:28pm
RRSV8
Thanks lads, any links where I can buy the complete sleeve from ?
& is it best to use ZF lifeguard 6 fliud also any benefit in adding dr tranny lubegard?
Post #565896 Wed Sep 26 2018 8:32pm
Have you seen the price of ZF fluid Shocked
Need 6 - 7 litres for a proper change
examples
https://www.ebay.co.uk/itm/Range-Rover-Spo...Sws6ZaH9g-
https://www.ebay.co.uk/itm/Genuine-Zf-6HP2...Sw81dZuTzN
both contain sleeve
https://www.ebay.co.uk/itm/BMW-ZF-6HP26-Tr...Swa~hZZIos
You don't add dr tranny lubegard for fun, so no.
Why are you servicing it?
You also need to work out how to get the 2 litres out the torque convertor.
Various ways.
1) Drain sump, undo oil cooler pipe at front of car (easy). Leave the car parked for a week. Re drain sump and measure what comes out.
2) Drain sump, leave plug out. Run engine for 20 seconds and more fluid should pour out sump
3) pump it out the front oil cooler line by running engine for 20 secs. Drain sump for any that is left.
You also need to get the fluid back in!
Gravity thru level plug.
Add 2.5l
Add another 2.5l
Run engine while quickly adding remaining fluid
or
put it in under pressure thru front cooler line with garden sprayer (much easier if you get a good pipe connection to radiator)
https://www.disco3.co.uk/forum/filos-autob...55010.html
Post #565898 Wed Sep 26 2018 9:10pm
RRSV8
Thanks Andy can you recommend alternative fliud ?
Also will gearbox need any programming after service ?
Post #565899 Wed Sep 26 2018 9:19pm
well
liquid moly 1800 as link above
Ravnol is popular
https://www.ebay.co.uk/itm/4L-LAND-ROVER-D...xyJX1TByuO
This link isn't cheap, but an example
Smith & Allen
search for zf6hp if you want to buy things for your gearbox
Post #565901 Wed Sep 26 2018 9:30pm
Gandalf
Ravnol Thumbs Up was recommended by my indy took me a couple of hours now have a shiny metal sump pan. Used some gasket seal as well as the supplied gasket belt and braces I know but hey Land rovers don't need an excuse to leak If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #565903 Wed Sep 26 2018 11:12pm
