Home > Faults & Fixes > Front Right oil leak, suspect it’s ARB. |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
I reckon they would fit through the gap ok and as long as the pipe is rated above say 450-500 Bar (that gives a safety margin above the max operating pressure of the system). It would need to be secured to the chassis as you wouldn’t want a flexible pipe snagging on anything. 2012 5.0 SC AB
Fri Jul 12 2019 11:45am |
jimmybee Member Since: 11 Jul 2019 Location: Liverpool Posts: 3 |
awesome thanks for response |
Fri Jul 12 2019 11:56am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Out of interest, did you fit dampers or leave it as it was without them? Kev
Sun Jul 28 2019 9:53am |
Is that a question for me?
Sun Jul 28 2019 1:21pm |
Yes it was and thanks.
Mon Jul 29 2019 10:57am |
jig Member Since: 14 Jan 2018 Location: London Posts: 17 |
Hi Britplumber, hoping to get some help and advise based on your repair on the hydraulic pipes on your range rover. i have the lower pipe corroded, can you help me with...
Sun Jan 24 2021 7:47pm |
How do I cut these pipes? Angle grinder hand saw, is there risk of filings getting into the system?
Mon Jan 25 2021 8:57am |
bump |
Mon Jan 25 2021 9:47am |
I’ve replied to your PM. 2012 5.0 SC AB
Mon Jan 25 2021 10:45am |
Yanee6804 Member Since: 12 Apr 2021 Location: Essex Posts: 15 |
Hi guys
Fri Feb 16 2024 10:09pm |
Yes you can, but I’d go for Stainless as the price difference is minimal. Also, you will need to cut back to area with no corrosion so the olives can seal. Any pitting or ovality in the pipe risks a leak. 2012 5.0 SC AB
Fri Feb 16 2024 10:38pm |
Thanks Plumber
Fri Feb 16 2024 11:14pm |
Disco_Dave Member Since: 23 Feb 2024 Location: Sleaford, Lincs Posts: 2 |
Hi Britplumber,
Fri Feb 23 2024 12:01pm |
Hi again Britplumber,
Fri Feb 23 2024 1:01pm |
