![]() | Home > Technical > Battery voltage before running. |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Mine goes down to about 12 volts overnight. I know cos I’ve programmed my dash cam to turn off if 11.9 volts reached and most days it stays on overnight.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
If it's 12.2V before you unlock it i.e. fully asleep overnight, then it's about 60% charged. Fully charged is about 12.7V. Bear in mind that unlocking the vehicle starts to wake things up so the voltage across the terminals will be slightly lower. Checking via a towing plug allows you to get a proper at-rest figure. Ideally you would leave it 24 hours after any running to allow surface charge to dissipate and thus get a true reading. 2012 SDV6 - it's missing a couple of cylinders
Special programmes unavailable can be a sign of a brake light or brake switch failing. Special programmes use HDC and this is hard wired in to the brakes. Any brake bulb or switch failures will usually cause an HDC failure and thus the error message. 2012 SDV6 - it's missing a couple of cylinders
I checked mine this morning, it hasn’t been started this week yet, no interior lights etc come on when opening, and it read 12.72v from + terminal and earth point on car, so that doesn’t seem bad at all by comparison, perhaps just slightly high? |
Fully charged is pretty good, yes! |
Jampot has put the kiss of death on my RRS! |
New battery from Halfords. 5 mins to fit, and all’s well again |
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 ![]() ![]() ![]() |
Glad you sorted it.... What battery did you go for?
I went for the Yuasa 5 Year Guarantee HSB019 Silver 12V Car Battery. There's a bit of a deal on with Black Friday coming up and 5 years guarantee seemed about right to me.
Oh dear |
Just a thought. If I have to have a new alternator, is there anything else I should be thinking of doing during this work? Robin
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Just on a side note, when exploring the IID tool i noticed you could update the battery settings. was this done when you replaced the battery. unsure if the EMS would prevent a charge if it thinks the dead battery is still connected? |
Oooh. Wasn't aware of that, thanks. |
So, an update in case anyone is interested.
