Home > Off Roading & Green Laning > Winch Cherry |
Might be worth getting a ground anchor for the RRS as well in that case, especially if you have no really beefy trees that you can put a tree strop around to stop the RRS from being pulled toward the bogged in tractor........... you utilise the tow bar for both the tree strop and the ground anchor. Or a set of beefy sand ladders for the tractor!
Sun Jul 09 2017 11:03am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1049 |
Thanks Tim, will think about that. I do (currently) have masses of trees (overgrown hedge) around to which to do that with and the tractor is only 880kg, so hopefully tractor won't get that stuck!
Sun Jul 09 2017 8:36pm |
El Matador Member Since: 04 Aug 2017 Location: Texas Posts: 3 |
Nice! What winch / winch bumper combo are you using? I'm looking at one myself |
Fri Aug 04 2017 8:53pm |
Well, had to winch a 7.5 tonne flatbed out the mud this morning! I needed some gravel at the entrance to a field as its getting a bit boggy and had some delivered. Only problem was that the truck got itself stuck after it had unloaded (guess I need some gravel eh?), so once again, winch to the rescue!
Fri Oct 27 2017 9:29am |
Just be careful with a wire and the rating for heavy stuff mate because when it goes it goes in a spectacular fashion! Seen it happen at a pay and play day and it wasn’t pretty!! Hope you use a cover damper on the wire 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri Oct 27 2017 9:33am |
Thank you Hence the need to replace with synthetic! On my (extensive) shopping list... |
Fri Oct 27 2017 9:41am |
Suggest that you periodically (every 5-6 months even with no use) run out the wire - wear riggers gloves while doing it in case of broken strands - examine it for surface corrosion and open up the wire lays and check that there is no internal dryness or corrosion. The legal time to condemn any lifting wire is when you have 10% of the strands in any 8 diameters length broken. Lubrication of the wire with a good quality wire lube or fish oil (very good lube but you will stink of rotten fish for weeks afterward!), never use grease though as it doesn’t penetrate to the Centre of the wire and can trap dampness in the strands.
Fri Oct 27 2017 9:53am |
