Home > General (L494) > BRAKE PAD CHANGE
kljw
Scotland
BRAKE PAD CHANGE
Hi
need to change brake pads on my 14MY 4.4 Sport fitted with Brembro's. I have been advised that the rear calliper needs to opened electronically.
his this correct?
and if so, how is this done?
no warning light is on as yet, so I also assume t]I do not need too change the brake sensor.
Keith
Post #524894 Sun Apr 30 2017 7:27am
Tyrefitter
You will only have Brembo brakes on front & these don't need winding in electronically if it the rears you are changing then yes they need winding back electronically.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #524897 Sun Apr 30 2017 8:44am
mlines
From another forum
You have to activate an e-brake service mode... Procedure is as follows:
- Turn the ignition ON (not the engine) by pushing the start/stop button without stepping on the brake pedal
- Push the e-brake button down for 2 seconds and hold it (release the e-brake)
- Push the accelerator pedal down for 2 seconds and hold it
- Push the start/stop button twice (turn the ignition off and on)
Now the e-brake service mode is active.. you will hear a noise from the rear e-motors, when its releasing the e-brake to the service mode. Still hold the e-brake button and the accelerator pedal.
After the e-motors stops there will be info on the dash that the e-brake service mode is activated.
To deactivate the service mode is the same procedure, the only change is that you have to pull the e-brake button.
It then suggests you can change the pads as normal after this, pushing the pistons in using a standard tool.
I have checked the process on my MY2016 RRS and it works (but have not changed the pads!) 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #524919 Sun Apr 30 2017 3:52pm
wilf
http://www.rrsport.co.uk/forum/topic47167.html
This is what I did when I changed the pads on mine.
BTW, EBC Redstuff pads have virtually eliminated brake dust on the wheels. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #524937 Sun Apr 30 2017 8:16pm
kljw
Scotland
mines
a couple fo points to clarify..
release after two seconds, or keep holding?
fast cycle or should allow the electronics to boot up?
many thanks.
Keith
Post #525044 Tue May 02 2017 8:51am
wilf
This is what I posted, hope it answers your questions:
Ignition on, engine off:
Hold EPB switch in "off" position for two seconds, then, keeping it pressed, floor the accelerator for two seconds.
Holding both in the same position, toggle ignition off then on rapidly - EPB goes to "service" or "maintenance" mode.
Turn ignition off and replace pads.
To reset - do the same thing but holding the EPB switch in the "on" position. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #525079 Tue May 02 2017 1:33pm
kljw
Scotland
All
thank you for the responses, it worked.
Keith
Post #525103 Tue May 02 2017 5:39pm
wilf
Excellent, well done. I admit I was holding my breath when I did it, too. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #525109 Tue May 02 2017 7:55pm
kljw
Scotland
Hi All
One last question, looking in car parts for less web site, there appears to be two types of rear pad, one with bolts and one without, how do I determine which are correct for my sport?
Keith
Post #525116 Tue May 02 2017 9:51pm
IRBails
Australia
quick question, I assume that there are wear indicators that need replacement when pads are changed. Anyone know where to purchase these? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #525207 Wed May 03 2017 10:34pm
wilf
Dealer, only source as far as I know.
Not sure about the two types of rear caliper, sorry. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #525211 Wed May 03 2017 11:47pm
