![]() | Home > General (L494) > First service showing already! |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Worth getting it checked, could be a rising oil level?
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
Now funny enough my Land Rover Remote App on my phone has been saying service due after I done about 6000 miles and the car is 9 months old, but there is no "Service" warning on the dash of the car. Notified dealership and they told me not to worry |
m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 310 ![]() ![]() |
Car is now showing service is due, booked in online with local dealer for next week & will call them tomorrow about my concerns as the car is only just over 7 months old with less than 5000 miles on it? |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1678 ![]() ![]() ![]() |
InControl Remote on mine shows service due and low washer fluid, neither of which is true. |
Phil, mine has been both showing in the car & on the app, no other warnings or lights & the oil level is still ok so who knows? Will discuss with service in the next hour. |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
Service indicator on mine shows exactly 40 days from the date of registration, both on In-Control and on the dashboard. Did it in the first year, and has just started showing again.
Update, Had the car checked today at local dealer, turns out as it was a showroom stock car the pdi which was done in late June triggered the service timer even though it was not registered until 1st September, they say as we do mainly short journeys the sensors have picked this up and brought the service forward, it's been serviced now under the 5 year plan so hopefully that's it until next April at the earliest.
Revoke Member Since: 03 Sep 2017 Location: Gainsborough Posts: 14 ![]() ![]() |
Any premature Service Required message on the 3.0 litre diesel is possibly being caused by excessive diesel dilution of the engine oil. There is a Service Compliance Notification dealing with the issue, JLRP00100.pdf, which can be downloaded from here-
kmpowell Member Since: 23 Oct 2016 Location: UK Posts: 259 ![]() |
For those of you getting a warning on the App, but not in the car, please read my thread here and more importantly my update in post number 6 that says about the N0101 update...
From Jaguar LR about important not to miss this.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Reading the LR leaflet, it appears that driving style / duration is a big factor in this. Presumably short journeys and low mileage are big issues. Long journeys should be a good thing as it will prevent the DPF regen cycling that appears to be the root cause. 2012 SDV6 - it's missing a couple of cylinders
Short journeys are definitely bad news but long journeys are not enough on their own so active dpf regeneration is always needed to keep the dpf clean. Thats what allows fuel into the oil and when it reaches 6.1% the car asks to be taken for a service ahead of the expected mileage. N025 lets the dealer reset the diesel counter without upsetting the date / mileage counters. |
Important. If your car was registered after a certain date as in my notice link, and you ignore the early service warning or oil warning and your engine seizes up or fails, then this is down to you not JLR, |
