Home > Technical > L494 EPB reset
wilf
L494 EPB reset
Anyone know the EPB reset procedure on a MY16 L494 3.0D HSE D (with the TRW rear calipers that have the EPB motors mounted directly on the back of them?)
I did look at the "brake bible" referenced a few times here, but it seems not relevant to this setup. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #520324 Wed Mar 08 2017 1:07pm
wilf
Bump - anyone? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #520494 Thu Mar 09 2017 10:18pm
Been-and-dunit
HI Wilf, Took my rear pads out remove epb electric connection and removed calipers to clean ,put all back together with no epb issues. Just make sure epb is off before attempting work ,
Post #520574 Fri Mar 10 2017 8:07pm
wilf
Thanks. Lots of googling and I found a late model Evoque procedure which seems to work. Puts the EPB into "maintenance mode", i.e. fully retracted, while you replace the pads.
When I have proved it, probably tomorrow, I will post it up. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #520589 Fri Mar 10 2017 10:33pm
wilf
Yes, the Evoque procedure worked.
Ignition on, engine off:
Hold EPB switch in "off" position for two seconds, then, keeping it pressed, floor the accelerator for two seconds.
Holding both in the same position, toggle ignition off then on rapidly - EPB goes to "service" or "maintenance" mode.
Turn ignition off and replace pads.
To reset - do the same thing but holding the EPB switch in the "on" position.
My Sport now has redstuff pads all round. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #520628 Sat Mar 11 2017 6:31pm
mgriffico
Hi,
How do the pistons in the calipers retract when fitting new pads? Is it just a case of pushing them back or twisting? I read somewhere it is done electronically, but hoping not.
Regards
Post #575597 Wed Feb 20 2019 3:12pm
wilf
I just levered mine back. No twisting required IIRC. Could w ell depend on actual brakes fitted. Mine were Brembos. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #575620 Wed Feb 20 2019 9:41pm
mgriffico
Thanks Wilf, I’ll have a crack at it then.
Post #575643 Thu Feb 21 2019 11:00am
