Home > Wheels & Tyres > What 19 inch rims will fit RRS with Brembo brakes |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4852 |
Part No. for this wheel is LR014979 I think maybe Style 5
Cheers Col |
Thu Jun 01 2017 10:54pm |
These are top picture RRC002900MNH Bottom Picture RRC502280MNH
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Thu Jun 01 2017 11:02pm |
Cheers guys. Hopefully getting somewhere now. Robin
Thu Jun 01 2017 11:43pm |
Hmmm. I'm starting to doubt myself now. But what else could it have been that meant my wheels fouled the brakes? I'm rushed off my feet work wise at the moment. Hopefully it will get easier in a month and I can have a proper look.
Thu Jun 15 2017 11:43pm |
The problem isn't the discs it is the calipers casing - there are two black plastic covers that stick up from them and they foul the wheel IIRC. Removal of them unfortunately is a non starter as they are dust caps for something (excuse the technical language!). 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jun 16 2017 3:09pm |
OK - I bit the bullet today and ventured into Harwoods, Lewes parts dept for a definitive answer . After some faffing to get my VIN and some clicking of a keyboard they pronounced that on my car the minimum size is 20 inch wheels.
Fri Jun 16 2017 3:48pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Strange. My 08MY TDV8 wears 19 inch rims quite happily over its Brembo calipers. 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 16 2017 5:29pm |
As did my TDv8 when I had it
Fri Jun 16 2017 5:33pm |
AGGGHHHH
Fri Jun 16 2017 5:50pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Fri Jun 16 2017 9:02pm |
I will be going 18" comps PD1881 shortly 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri Jun 16 2017 9:16pm |
That's interesting Buckster. Had a look at them and noticed this comment:
Fri Jun 16 2017 11:25pm |
Phonic dampers are the plastic things I mentioned earlier 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jun 17 2017 6:24am |
The Phonic Dampers are the rectangle blocks at each end of the caliper, held on with a allen screw I think. If you remove them you may well get noisy screeching brakes as they are dampers to prevent this, if I understand correctly.
Sat Jun 17 2017 9:03am |
