![]() | Home > Faults & Fixes > Grinding noise moving at low speed when cornering? |
JonD-RRS Member Since: 15 Mar 2016 Location: Lancashire Posts: 16 ![]() ![]() ![]() |
Rear brakes stuck?
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 84 ![]() ![]() |
Well it's been into an independent specialist CR Allen, and it's been diagnosed as the e-diff actuator?
Thought it was probably too obvious but thought I would give it a go.
Well along with 2 new rear Tyres, 4 wheel alignment, new diff actuator, reprogramming and diff update, new lower arms (front)! Around £1650 +VAT |
Ouch!!!!!!
Well thought I'd give a little update, got the car back Monday and all seems well! Very well which is a great relief as spending that much on it has hurt but on the grand scale most of the works were expected maintenance items so as long as she's driving well it all good!! RRS Autobiography SDV6 19
glad its all sorted. |
Thanks |
NTBeyond Member Since: 03 Nov 2010 Location: Darwin Posts: 28 ![]() ![]() ![]() |
I had a similar problem. The dealer said it was a Transfer Case oil degredation problem. They checked TSB and found fault #LTB00906V6 They fixed the issue under warranty. Cheers 2014 SDV6 HSE, Panoramic Roof, 825w sound, Surround Cameras Gone: MY10, TDV6 Sport, Zermatt Silver, Sunroof, 18" Rally alloys. 2006 Pajero Exceed, Silver |
Chrisb1985 Member Since: 01 Oct 2017 Location: Buckinghamshire Posts: 1 ![]() ![]() ![]() |
I have a similar issue with mine it’s not just at low speeds but it’s mainly when turning left. Range Rover thought it’s was the arc bars but they have fitted new ones and has not solved the issue. Iam hoping what you had is the same. Has the the work you had done still fixed the issue. For some reason when the stability control failed on mine the noise disappeared that’s why they thought it was the arc bars. |
