![]() | Home > Maintenance & Modifications > LED High Beam Replacement |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Hi Everyone,
TBH I think anyone who does any back lane driving would find these beneficial. Even new sports, disoc's etc. The high beams are all halogen |
I found the Adaptive Bi-Xenons excellent on the country lanes in Central Scotland when I had my TDV8 RRS and both Evoques, pity my current car doesn't have them - I have no issues with the non-adaptive headlights in my 2015 HSE Dynamic though, excellent spread and brilliance on main as well as dipped. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
A number of years ago, I was a member of the SIDC (Subaru) and they arranged for an Essex traffic officer to give a talk to a number of members. One of the questions asked was the legality of higher wattage bulbs and he said that they are not illegal to use on the road. He did go on to point out that deliberately using them to dazzle other road users was an offense however. That goes for any lights that might dazzle another road user, high or low power and why they often pull people with front fogs on. |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
Bulbs aren't road legal unless E-marked, and to be E-marked they have to meet the brightness and wattage criteria, so no, high wattage bulbs aren't legal. Excellent in a good pair of lamps though.
Nope, unless they are halogen units, they all have bi-xenon units also (as does yours). The RRS2/L405/late D4 do have poorer lamps by losing the halogen beam though. Bear in mind, the LEDs will look significantly brighter than they actually are because of the colour temperature, and you will disrupt the beam pattern - there is no way to avoid that, even in the best of LED retrofits. Don't want to put a dampener on it, but I can guarentee you, the improvement to vision won't be as drastic as it looks to be - you need a narrower beam to really see far. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Wasn't aware that new motors were using xenon as high beam, I thought thay weren't used in that capacity as they don't like being flicked on/off and have a warm up time ?
The xenon units use a shutter to block the upper part of the beam, so yes the bulbs are always lit. It's not just new vehicles but yours too. |
The positioning of the led's on the kit I bought are very close to that of the stock bulbs fillament, but as I said earlier these bulbs work well in the RRS, in another vehicle they will no doubt suffer.
No LED will truly fit the focal point though, as they have to be mounted on something and the thickness of that alone places them outside the focal point. |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
Uprated bothe the headlights and spots on my defender last month, when the spots are on makes the sports light look like a pair of candles. It's like driving in daylight.. |
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
Do you put the |
Seeing as how Socast didn't take photos or owt when he replaced his bulbs with LEDs, thought I would fill the gap as its a bit fiddly...
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 ![]() ![]() ![]() |
They look excellent, thinking I'll be treating myself to a pair of those! Tried them out in the dark yet,?
Had a little drive last night and wow, all I can say is very bright! In fact so bright that turning on the spots didn't really add much other than light up the trees 200+m away... Previously there would be a marked improvement when I did so, including lighting the trees.
