Home > In Car Electronics > What dash cam
Page 2 of 3 <123>
Paddi
Things move on very quickly in the tech world and there is a £100 camera catchily named the DDPai M6+ that has a good review by the legendary TechMoan:
http://www.techmoan.com/blog/2016/6/23/das...-used.html
If my Mini 0803 lets go then I might give this a whirl. Particularly like the parking mode feature and the wi-fi 2008 MY Java Black TDV8 HSE
Post #507565 Tue Oct 11 2016 12:49pm
Eaters
Just purchased a Thinkware F770 twin camera with hardware kit. Should I be seeking out a piggy back fuse connector for the hardwiring bit? Is there anything else I should be thinking about for a self install? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #507986 Mon Oct 17 2016 6:03pm
Tyrefitter
I got the piggy back fuses for mine but when the guy came to install my tracker he hardwired the dash cam in for me Thumbs Up..I don't know which fuses he wired in to as I wasn't watching him.You need to check the fuses as you need a constant live,,ignition live & a earth.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #507987 Mon Oct 17 2016 6:35pm
Eaters
Cheers Andy
When the kit arrives, I'll have a play around, but thanks for the heads up. Might order a piggy back now just in case. Robin
Gone:
MGZTT 190 2.5
Post #508019 Tue Oct 18 2016 12:40am
ilard
I would be interested to see some photographs of how Thinkware 770 front & rear cameras look when they are installed. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #508307 Sat Oct 22 2016 8:19am
Eaters
Can do. Had a little battle with the suppliers yesterdayas I ordered it last Monday on a 2-3 day delivery timescale and seen nothing yet Censored Robin
Gone:
MGZTT 190 2.5
Post #508309 Sat Oct 22 2016 8:26am
jimcarver999
England 2012 Range Rover Sport SDV6 HSE Lux Alaska White
Was looking at getting the thinkware 770 but from what has been said do you all think getting the 750 is a better option and just update the firmware , what would be the difference in them??
Andy.
Post #508311 Sat Oct 22 2016 8:33am
Eaters
I went for the 770 as I was not sure if the firmware upgrade includes the improvements to super night vision camera. Also the time lapse improvements. And for another £30 or so, it seemed worth it - that's just a third of a tank of fuel after all Robin
Gone:
MGZTT 190 2.5
Post #508313 Sat Oct 22 2016 8:50am
Tyrefitter
This is where I mounted my 770,1st pic where it was before then I moved it below the mirror to get the gps to connect quicker.
Mmm can't work out why 1st pic ended upside down.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #508338 Sat Oct 22 2016 2:28pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
Danv8 wrote:
I have a nextbase 402g installed, it's good but they all suffer from internal battery fail normally around 10 months, so then it's back to the seller to try claim for a repair under warranty, if your lucky it fails well with in 12 months. Mine died at 11 months so I had to buy my own internal battery (took a lot of googling to find the right one) and begin minor surgery replacing it.
This would be my next choice
http://www.argos.co.uk/static/Product/part...AmB-8P8HAQ
Can take a 64gb card where the nextbase is maxed at 32gb.
This guy is on another forum I frequent, I also subscribe to his you tube channel, but this definitely highlights the usefulness
Have you a got a link to where you got your battery from mate? I have the same cam but its telling me the battery is low (although its permanently hardwired Rolling Eyes)
Post #508360 Sat Oct 22 2016 8:32pm
Eaters
OK, camera now received and installed. I wired mine to Fuse F12 (horn) for the permanent live feed, and F47 (which has a switch symbol I think) for the Switched live. I used one of the glove box fixing bolts for the earth lead.
Went out for a jolly to try it out and picture quality seems pretty good.
I like the PC app you can download as it allows you to see both front and rear cameras synced together. The USB interface is very clever as well, or there is a standard SD card adapter for the micro SD card.
I have downloaded the latest firmware and speed camera data - very straightforward - just follow the instructions on the web site.
Not keen on being nagged by the built in (american) voice and I am sure I will reduce her chatter over time but at present I have all the bells and whistles turned onto evaluate them.
Wire routing for the rear camera was OK - I just felt I should be careful not to impede the multitude of airbags as I went from the front to the back. Notice that you need to leave a loop of wire by the rear camera to allow for boot opening.
 Robin
Gone:
MGZTT 190 2.5
Post #508622 Wed Oct 26 2016 9:12am
Johnski
Eaters could I just query why you didn't fit your rear camera at bottom of screen rather than top, and inside the wiper sweep? John
Post #536126 Thu Sep 21 2017 10:28pm
Eaters
Hey John. Good question. One to which I don't have an immediate answer. Embarassed
I'll have a look and get back to you. Robin
Gone:
MGZTT 190 2.5
Post #536128 Thu Sep 21 2017 10:52pm
Eaters
Right John. Had a look. As best I can work out, I think the supplied cable may have been a bit marginal for length, it may have given a poorer view being lower down, and I was probably a bit too lazy as it would mean taking the cable down the side of the rear screen and the across.
I could move it down a tad to get within the wiper sweep. And perhaps at the same time I could hide the exposed cabling... Thumbs Up
Regards
Robin Robin
Gone:
MGZTT 190 2.5
Post #536735 Fri Sep 29 2017 11:11pm
R44dgf
Goluk t3
Hi after a lot of searching about I found £ for £ the goluk t3 was the best for me easily fitted with The hardwiring kit into the fuse box no wires seen anywhere and hides unseen from the drivers seat
Around £115 off eBay
Post #536744 Sat Sep 30 2017 9:01am
Page 2 of 3 <123>
