Home > In Car Electronics > Parking aid/reverse camera unavailable? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4807 |
My RRS1 has this speaker in the rear.
Mon Jan 23 2017 1:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4865 |
Not sure if it is of any relavance but on my MY13 RRS 1 the sound from the Rear Parking Sensors actualy come from the Rear Door Speakers on both sides.
Mon Jan 23 2017 10:03pm |
Yes that does help.
Mon Jan 23 2017 10:16pm |
I know you can adjust phone, satnav volume etc. through the menu but not sure if parking sensor volume is in there, will have a look later.
Mon Jan 23 2017 10:26pm |
abilover Member Since: 03 Oct 2016 Location: East Yorkshire Posts: 29 |
The plot thickens!
Mon Jan 23 2017 10:48pm |
Just thought I'd post and draw a line under this fault, to possibly help someone else.
Sat Feb 04 2017 11:44pm |
kansanbrit Member Since: 01 May 2020 Location: Kansas Posts: 4 |
I know this an old post but I had this display shown on a car I bought. I tracked it down to a bad parking sensor on the front bumper. Apparently any faulty sensor front or back will stop the camera working. I also noticed that as my battery ran down while messing with the car with the ignition on it stopped working again although the parking warnings were still working which they weren't initially. As soon as I drove the car and got the battery charged up it started working again, so it is quite voltage sensitive. |
Mon Jun 01 2020 9:04pm |
pomistea Member Since: 03 Jun 2021 Location: Dublin Posts: 36 |
If you unplug a rear parking sensor, will the camera and sensor system stop working? |
Thu Feb 16 2023 2:07pm |
For hopefully someone else’s benefit.
Sat Feb 18 2023 11:31pm |
Barry webb Member Since: 01 Jun 2023 Location: Cornwall Posts: 10 |
Thank you for putting this info on the forum I've had the rear camera problem for over 0ne and a half years I've replaced the camera but it's still not working.
Thu Jun 01 2023 11:08am |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
It could be any one of the 8 sensors that takes the system out, in my case it was a wire in the loom to the front inner left so I can a new cable and the system was back online.
Thu Jun 01 2023 11:17am |
