Home > Faults & Fixes > help needed strobe brake light
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
I have a bit a odd ball guys Shocked
My brake lights and gear selector solenoid are activating on there own like a flickering effect. Yet when i turn the car exterior lights off completely, the brake lights and gear selector operate on normal function by depressing the brake petal. All bulbs seem to be fine nothing blown and no change of bulbs have been made in the last few months.
Could any one shed any light on this, or any dianostics procedures i can preform.
Post #486741 Sat Feb 06 2016 8:07am
First thing to look at must be the brake switch on the pedal. Cheap (about £15 I think) and quick DIY fix. 2012 SDV6 - it's missing a couple of cylinders
Post #486745 Sat Feb 06 2016 9:10am
Saeedasghar
Just a update on the issue I had.
On advise from fellow forum member sourced a brake light switch and swapped that out didnt take to much time at all. Good start point but unfortunately not the answer.
Got it on the local indy diagnostic and it came up as Body Electric Control Module (BECM). Got my self booked in with him but i had a gut feeling it would be simpler than that.
So then i started thinking maybe its a bulb, checked all exterior bulbs nothing all illuminating as they should.
I then took passenger and the driver side rear light out and disconnected it from the clip turn by turn, appeared to be a short in the wiring at the cluster on the driver side rear. Quick rummage round the old garage and found a spare light i had knocking about swapped it over and everything was spot on. Thumbs Up
I have now joined thr many other rrs owners who have experienced the dark side to the electric gremlins caused by a simple problem. Hope this helps any one else who may come across with similar issues. At least its one direction to start looking.
Post #487280 Fri Feb 12 2016 4:06pm
SH0X
Maybe a bad bulb or circuit in the cluster. Very big problem to come from a bad light 😯
Post #488981 Fri Feb 26 2016 4:07am
Saeedasghar
It was definitely in the wiring I did swap all the bulbs for new ones once I knew the replacement worked just to be on the safe side for that very reason, and yes such a strange issue from a wire
Post #489044 Fri Feb 26 2016 3:46pm
