![]() | Home > General > ctek mxs5.0 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
This is good value.
Unfortunately not. Has to be 13pin or the grey 7pin
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
yeah had a funny feeling it would be to good to be true ,so just have to fit the comfort lead then. how did you fit yours if you don't mind me asking ? |
If the cigar lighters function with the ignition off, then you could buy a lead to connect into that.
I did buy the cig lighter connector but been told the sockets all shut down when the car goes to sleep, the connector that came with it has m6 eyelets do these not fit ? |
Does the socket in the boot also shut off ?
Ok mate I will do |
JanRRS Member Since: 29 Dec 2015 Location: in my car ... Posts: 41 ![]() ![]() ![]() |
Hello, I want to connect my Ctek 5.0 directly to the battery using the comfort connector ... Has anyone done this? As I am yet not too familiar with my new RRS, am I correct in assuming that the battery is under the spare wheel in the back? Thanks |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
Hi, I assume you are referring to an L494 when you say "new" HSE. No model designation in your profile. This really helps when you are requiring assistance or information.
Thank you Jock. |
Personally I just use the crocodile clips that came with the CTEK charger direct to the terminal posts in the engine compartment because it is convenient for me and the arrangement of the power sockets in the barn where I keep the car.
Thanks Jock.
Thanks Jock. Terminal posts found, and Ctek running! ![]() Jan |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
I recently bought a CTEC 5 charger. I have a 2011 RRS so can I connect the comfort wire to the battery and us that? |
