Home > Off Topic > Range Rover evoque won't start after airbag replacement |
Sorry i have no idea, so i can't help you.
Thu Dec 17 2015 7:29am |
Newbie Member Since: 16 Dec 2015 Location: Nottingham Posts: 4 |
Thank you |
Thu Dec 17 2015 8:46am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4965 |
As you have had airbags changed I guess you have had some sort of impact, just as a thought has the Inertia Fuel Shutoff Switch triggered as I imagine it has one off some sort, although you don't say whether the engine turns over or not, wouldn't know just a suggestion.
Thu Dec 17 2015 12:49pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8967 |
If a shunt, has the Megafuse blown? This isolates starter and alternator but allows power to rest of vehicle. 2012 SDV6 - it's missing a couple of cylinders
Thu Dec 17 2015 1:21pm |
It's been on a machine at a Range Rover specialist today who says the Ecu isn't talking to something I forget what and new software needs to be ordered from Range Rover garage said checked mega fuse as on battery it cranks but that's it |
Fri Dec 18 2015 7:55pm |
I am the forum moderator of BabyRR.com and have owned two Evoques. I had a lot of problems on my first one with the Battery Management System that was causing the bettery to flatten very very quickly. It transpired that when the battery was disconnected to replace it the Land Rover Assist guy was not resetting the BMS after the reconnection of the battery. This is a stab in the dark as the problem was supposed to have been fixed with a TSB that was applied when cars went in for servicng. Once mine had had a new style of battery (an Absorded Glass mat battery) and a BMS software upgrade I never had another flat battery but it took 3 months of flat batteries to find the problem!
Fri Dec 18 2015 8:20pm |
Thank you will mention it to garage tomorrow cheers |
Fri Dec 18 2015 8:58pm |
