Home > In Car Electronics > Tow bar wiring
itsmeagain
Tow bar wiring
How easy is it to fit the wiring for the tow bar electrics, as mine doesnt have any. Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2012 Audi A1 2.0litre Black Edition TDI
2004 Audi A4 convertible
2004 Audi A2 TDI
Post #444569 Sun Dec 07 2014 6:01pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Very easy, if you buy the kit It's basiclay plug and play.
I just bought a £7 trailer plug with 2 meters of wire and made my own. I had some old conectors at work and just removed the pins. Fitted them into the blanks that plug into the trailer connectors behinds the near side boot trim. Spent 5 minutes with a test lamp checking what pin does what and soldered up the right connections.
Post #444576 Sun Dec 07 2014 7:02pm
itsmeagain
Any ideas how much the plug and play kit is?
Saw a few listed on ebay, doubt its that hard to fit Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2004 Audi A2 TDI
Post #444586 Sun Dec 07 2014 7:44pm
rich_sargie
£120 from landrover I think
Post #444588 Sun Dec 07 2014 8:04pm
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
I paid around £130 from the Local dealer. It's around 2 hours work if you've never done it before.
All the connections are behind the near side boot panel.
It's all plug and play.......................
You could go down the cheap looms from china/far east................... but do you really want to encourage electrical gremlins at a later date ?
Good luck.
Post #444594 Sun Dec 07 2014 8:19pm
Ovey
If you buy the plug and play set, do you need to have the tow software function activated on the car too? Or will switching the park sensors off manually be the only bugbear to put up with if you don't? Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Previous: Discovery 3 2.7 TDV6 HSE in Zambezi Silver
Post #450065 Wed Jan 28 2015 2:15pm
Gargy
You don't need to have the software update for it to work.
I had mine done for free when I had it serviced, as it's easy once the car is plugged in.
Post #450095 Wed Jan 28 2015 6:55pm
Ovey
Ok Gargy, thanks for the info. Thumbs Up Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Post #450202 Thu Jan 29 2015 2:23pm
CDS
The software update stops the car raising and lowering automatically when Terrain Response is selected, useful to avoid the back end of the trailer being inadvertently grounded Thumbs Up Over for a visit from disco3.co.uk
Post #450204 Thu Jan 29 2015 2:40pm
Bodsy
Site Sponsor
There is a difference between the 2009 and the 2010 model years.
2009 you can fit and everything will work (but won't stop you as CDS describes)
The 2010/11 model year, more often than not, needs to be enabled for it to work with the correct 12n/s or euro 13pin setup. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #450208 Thu Jan 29 2015 3:02pm
SRE
Spain
You need to make sure the rear fogs are disabled when the trailer is plugged in. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450226 Thu Jan 29 2015 4:09pm
Bodsy
Site Sponsor
i'd not heard that, is it a legal requirement of manufacturers for that function? Bodsys Brake Bible
See it HERE
Post #450227 Thu Jan 29 2015 4:11pm
SRE
Spain
The fog lamp cut out is sometimes undertaken by a simple metal strip in the tow socket, but not sockets have this.
You also need to make sure the rear parking sensors are disabled as well.
My sport is an 08 and it required coding.
Should add mine is the 13 pin euro plug In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450235 Thu Jan 29 2015 4:48pm
Ovey
So if I have a september 2009 (MY10 facelift) does this fall into the category of 2009 or 2010/11 in terms of what I'll need to do regarding fitting/activation?
Also, I'm guessing the fog light being de-activated is only de-activated on the car but still allows the fog light on the trailer to work? (My trailer is over 1.3m wide and legally requires a fog light to be fitted and working). Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Post #450246 Thu Jan 29 2015 5:13pm
CDS
It's a CCF edit IRRC Bodsy.....I always assumed it was to stop the reflection of the red lamps when towing something big like a caravan.... Over for a visit from disco3.co.uk
Post #450251 Thu Jan 29 2015 5:49pm
