Home > Technical > Water ingress
Nmc880
Water ingress
Hi all, I have noticed that I am getting rain water into my passenger side footwell in my 2005 rrs, I have had the sunroof drains cleared but the water is still coming in? After further investigation I have noticed the water is running down the square plastic tube that the electrics run down into the footwell on the left hand side, has anyone had water come in this way before, it is the standard windscreen etc and the the rest of the carpets are bone dry, are there any other drain holes I've missed, any info much appreciated, thanks
Post #441979 Sat Nov 08 2014 11:35pm
garrycol
Australia
The water will be running down the outside of the windscreen pillar - between the pillar and and the trim in through the oval shaped hole at the bottom.
There was s service bulletin on this a few years back.
I had the same issue last year. - I sealed the upper clips with some silastic and taped up the bottom oval hole and sealed with sealant. Fixed it straight away.
The service bulletin provides extra sealing around the oval hole.
See this post and the links inside it.
http://www.rrsport.co.uk/forum/topic35756.html
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #441987 Sun Nov 09 2014 3:46am
Nmc880
Thanks very much Thumbs Up
Post #442001 Sun Nov 09 2014 11:42am
Nmc880
Quick update, Big thanks to garrycol as fixing the A pillar holes has solved the water ingress problem, my car can finally start drying out now Bow down
Post #442653 Sat Nov 15 2014 2:07pm
BillHLTean
United Kingdom 2008 Range Rover Sport TDV8 Autobiography Firenze Red
found this thread which i hope will be useful fixing my water in my footwell problem
i will let you know
Post #623714 Wed Apr 20 2022 12:49pm
