![]() | Home > Maintenance & Modifications > Brake Pipes replacement on Range Rover Sport 2005-2009 |
Thebeloved Member Since: 09 Aug 2014 Location: Luxembourg Posts: 10 ![]() ![]() ![]() |
Good evening all,
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
Hi,
Thanks a lot for the valuable info. At least I know that I have to remove the wheels. |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
Just under the passengers seat is a heatshield, behind this are the two rear brake pipes, I cut these here and join with new copper pipe to both rear wheels job done in about 2 hours
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
Have you cleaned the pipes off to check how bad they are or is a dealer/tester telling you? |
Thanks Das,
thank you Flack. Do you have any pictures??
