Home > Maintenance & Modifications > removing interior boot panels
skywash
hi chaps i was wondering if anyone could help...i need to remove one of the panels inside the boot of my 06 sport anyone know how to get the off i cant see any fixings ie. screws or bolts.....thanks in advance
Post #425801 Sat May 31 2014 4:02pm
RonyTed
England 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Did this on Friday to access DVD Player so only removed offside but look like they are both the same. You have to fold back seats down and remove luggage blind (if fitted) then using a 6 mm allen key remove both chrome luggage retaining loops this allows you to lift up and remove the carpeted plastic trim panel beneath them. you then just pull the side panel nice and gently and it will release the plastic trim clips behind, peel back the rubber door and tailgate seals and the panel will come free. you have to remove the plug from the boot space interior light if doing that side and want to remove the panel completely.
Refitting is just as easy just make sure all the plastic trim clips engage before you push the panel back into place as they are soft plastic and deform easily.
Post #425878 Sun Jun 01 2014 3:45pm
skywash
thanks for the help m8..its the nearside i need to remove.looks like somebody gave the panel a knock but hopefully i can pop it out with the panel removed
Post #425927 Sun Jun 01 2014 11:53pm
