Home > General (L494) > TDV6 vs. SDV6 |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 |
SDV6.... as you said has the more powerful engine.... Plus far higher standard specification and greater choice of optional extras...
Fri Oct 04 2013 11:19pm |
DBA Member Since: 20 Mar 2013 Location: Skopje Posts: 51 |
The problem ism as I see in most EU countries, the SDV6 doesn't mean you also get HSE level of equipment - it is still an SE, specification with the grained lather, less number of interior combinations etc... so the 5k EUR I have mentioned is just for the engine (I guess engine software upgrade)...
Fri Oct 04 2013 11:33pm |
Interesting point..... I think it has been discussed on another thread and the general consensus was that it is a little bit more than re mapping or software only..... It really becomes harder to justify if thats all it is for 5k ish..... although there will be plenty including me that just ........ have to have the spec 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Sat Oct 05 2013 12:06am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
I believe the engine is more than just a different software install. The SDV6 has, I think, sequential turbos. I would agree that E5k is a bit steep just for the engine. If you got LR, TR2 etc. as well then it would be a better deal. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Oct 05 2013 1:05am |
Baco Member Since: 13 Aug 2013 Location: Belgium Posts: 154 |
I made a similar thread some time ago when I ordered mine. I first spec'ed out a TDV6, but that would mean no off-road/on-road pack, so I switched over to the SDV6 after all, I couldn't see myself buying a Range Rover without the off-road pack.
Sat Oct 05 2013 5:56am |
Wow..... I didn't realise they did a variant below the 258hp....... for some markets...
Sat Oct 05 2013 7:33am |
