Home > Maintenance & Modifications > Door Mouldings - Clips?
Sag
Hi guys,
The previous owner of my RRS has had the lower door mouldings colour coded but they are a very poor fit.
Every time I close the door, the trim wobbles about and looks as if it's about to fall off.
I assume I need new clips as the old ones have most probably broken.
2 questions:
1. Is the clip I need for these DYC101420?
2. How many would I need per door?
All four doors have the same issue.
Thanks in advance for any help Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #383029 Tue May 14 2013 2:08pm
Just ring your local stealer and he will have all the answers for you and give you a price for them too. Thumbs Up They arn't expensive.
Post #383032 Tue May 14 2013 2:21pm
SRE
Spain
http://www.rrsport.co.uk/gallery/albums/us...20clip.JPG Thumbs Up
http://www.lrdirect.com/DYC101420-Trim-Cli...=DYC101420 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #383041 Tue May 14 2013 3:07pm
duckworthparts
Site Sponsor
90 pence each
think you'd need 6 on the front door Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #383043 Tue May 14 2013 3:13pm
Sag
Thanks guys Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #383044 Tue May 14 2013 3:33pm
SRE
Spain
Worth checking that the moulding has not broken on the inside. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #383045 Tue May 14 2013 3:37pm
RRS_PAT
Absolutely as this can often be the case where the plastic struts on the inside come away resulting in wobble Sad
As new clips won't fix this its worth a look before you get some... 2011 Autobiography Santorini Black
Post #383052 Tue May 14 2013 4:58pm
Sag
Ok cheers guys, will check it out tomorrow before ordering any clips Smile LCFC. Receiver of threatening letters from Overfinch.
Post #383080 Tue May 14 2013 7:44pm
Sometimes you can just give the the moulding a hard smack and the existing clip will hold. I have the same problem on my RRS. 2012 SDV6 - it's missing a couple of cylinders
Post #383099 Tue May 14 2013 11:00pm
Sag
Guys, can anyone tell me how these lower door mouldings come off?
I Want to check if it's the clips I need or if the moulding is damaged. I'm thinking just a hard tug? Laughing LCFC. Receiver of threatening letters from Overfinch.
Post #395518 Thu Sep 19 2013 7:30pm
PEACHY
Sag - it's as simple as that - just give them a good pull Surprised I've had mine replaced but the same happened so replaced with new clips Thumbs Up 16MY Estoril Blue SVR.............
Post #395528 Thu Sep 19 2013 8:47pm
Sag
Thanks Peachy Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #395530 Thu Sep 19 2013 8:51pm
Red71
Australia
Hi Sag,
I did all this a few weeks ago here are a few picks,you should be able to count the clips you will need.I was lucky I only had to drill out the black ones on the rear of the front doors as I couldn't get them off??
There's a little screw on the inside of the rear doors you'll have to remove first.
I took the sill panels off as well as I fitted side steps and got the new ones colour coded too.
Hope this helps ya??
Some after pics
With the new side steps,grill,side vents,tread plate and a bit vinyl wrap on the bonnet and roof.
Paul 2005 RRS 2.7TD
2013 VW Passat
1967 Chevrolet Camaro
6.10 Trailcraft centrecab (Dust collector)
Post #395539 Thu Sep 19 2013 11:39pm
Sag
That is awesome Paul, thanks very much! Glad I saw that as I wouldn't have ordered enough clips.
Your RRS looks great by the way Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #395569 Fri Sep 20 2013 12:39pm
Red71
Australia
No worries Sag. Very Happy
I started with the lower tailgate trim first to see how much force I needed to use then after that it was pretty straight forward.
There's a couple of screws that you will have to take out in the front and rear wheel arches as well for the sills plus the big plugs underneath.
I was surprised at how much crap there was under the mouldings once I had taken them off as you can see from what's on the ground in the pics.
I fitted up new front and rear mud flaps when I put everything back on just to finish it off.
Yer thanks mine has been a work in progress over the last 12 months.
Almost finished just going to replace the badges with new ones and fit up the halo lights and paint the inners whilst apart and then a full detail and hopefully it's done but I'm sure ill find some other stuff to tinker with?? Thumbs Up Thumbs Up
All the best.
Paul 2005 RRS 2.7TD
2013 VW Passat
Post #395636 Fri Sep 20 2013 11:37pm
