Home > Maintenance & Modifications > Rear ARB leaking - O-Ring replacement?
RRSTDV8DK
Denmark 2007 Range Rover Sport TDV8 HSE Stornoway Grey
My rear ARB is leaking and i have been told it needs to be replaced. I seam to remember reading somewhere that it sometimes can be fixed by replacing the O-Ring. Is that correct and does anybody know if this is a kit and the partnumber?
I have a, not to good, picture of the leak: http://s17.postimage.org/fzxtn2y6n/IMAG0181.jpg
O-Ring replacement most be cheeper than ARB replacement ... RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #372343 Tue Feb 05 2013 3:03pm
Paddi
Were you thinking of this thread? http://www.rrsport.co.uk/forum/topic19778.html?highlight=o+ring 2008 MY Java Black TDV8 HSE
Post #372370 Tue Feb 05 2013 6:23pm
RRSTDV8DK
Hi Paddi
Yes and no - i've read that thread, but I don't know if it is the o-ring on mine or the ARB that needs changing.
Anybody have access to the Special Service Messages SSM41438 - Stabilizer bar fluid weep - Dynamic Response vehicles? RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #373276 Tue Feb 12 2013 10:44pm
Have a trawl through Bobby's gallery: http://rrsport.co.uk/gallery/index.php?cat=10024 2012 SDV6 - it's missing a couple of cylinders
Post #373295 Wed Feb 13 2013 9:45am
RRSTDV8DK
nope - not there RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #373958 Tue Feb 19 2013 12:25pm
Bobby
In order to correctly diagnose the leak path on a stabilizer bar, clean the suspected area thoroughly and confirm if
the leak is from the pipe o-rings, the stabilizer bar hydraulic seal or somewhere else. If found to be from the
pipe o-rings.... like here..
... these are serviceable parts and should be replaced.
If the leak is found to be from the hydraulic seal, this is not a serviceable part and a new stabilizer bar will be
required.
Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #373963 Tue Feb 19 2013 1:07pm
Well done Bobby! Bow down Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #374029 Tue Feb 19 2013 8:38pm
Bobby
No problems.
Would have responded to this sooner, only thing is that I was in the UK at that time! Was raining, in addition to being cold!!
Took the Eurostar to Paris on 14th... and back home now.
Cheers!! Cool
PS - Wonder if this helped RRSTDV8DK ? Malaysia Boleh!
Post #374302 Thu Feb 21 2013 10:59pm
Tommyschuck
2007 Range Rover Sport TDV8 HSE Sumatra Black
Does anybody know the torque of this two little bolts on the picture above?
Post #376977 Fri Mar 15 2013 6:03am
RRSTDV8DK
Hi Bobby
Thank you and sorry for the late reply.
It looked like it is just "sweating" so I had it cleaned up, but can not see where it is coming from - and no faults in the dashboard - so I will leave it for now. RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass
Post #383185 Wed May 15 2013 6:33pm
TheDB
required.
Smile
Hi Bobby,
Same for the front ARC stabiliser bar?
Post #395325 Tue Sep 17 2013 10:00pm
Bobby
Yes. Cool Malaysia Boleh!
Post #395363 Wed Sep 18 2013 10:19am
