Home > Wheels & Tyres > Cracked Alloy - what to do?
wilburn
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Hi,
Just noticed my front nearside tyre was flat so took it for puncture to be repaired only to find out the alloy is cracked.
I am guessing we had a slow puncture and driven the car with zero pressure = wrecking the alloy.
Been quoted £570.80 including balancing, fitting and VAT from local garage for a new genuine alloy wheel from land rover to be supplied and fitted.
I believe the land rover part number is 9H321007AAW and they are called "style 3"
One thought was to buy 4 brand new cheap alloys for £600 incase this happens again so it isn't so expensive to change one alloy but I am not sure on the quality of them for example, these http://www.wheelbasealloys.com/20_Inch_MAK...eels__7316
Are they really ok with the weight of a range rover sport on them?
Or do I source a 2nd hand alloy wheel that is the same spec size etc as the one that has cracked?
I.e. I have found this http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...3a763eb829
Can anyone help or advise please?
Thanks
Paul
Post #367882 Fri Dec 28 2012 5:21pm
Sag
Most cost effective (& safest) way is to get a Genuine LR wheel from eBay or somewhere and replace the single cracked wheel. LCFC. Receiver of threatening letters from Overfinch.
Post #367884 Fri Dec 28 2012 5:28pm
duckworthparts
Site Sponsor
got a picture of the alloy?
may have some in stock wheel tyres on Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #367886 Fri Dec 28 2012 5:40pm
sparky8181
Email the company and find out what weight the wheels are rated for, there have been discussions on here re wheels cracking due to the weight of the RRS.
If the wheels are adequate for the weight then no reason why you shouldn't get them as £570 from the stealership is extortionate!
Post #367887 Fri Dec 28 2012 5:42pm
wilburn
Hi,
Yes, I have just uploaded 2 pics here
Wheels are 20"
http://www.rrsport.co.uk/gallery/displayim...&pos=0
and here
http://www.rrsport.co.uk/gallery/displayim...&pos=1
Post #367888 Fri Dec 28 2012 5:48pm
duckworthparts
Site Sponsor
yep i've got this this style wheel in stock with a goodyear take off tyre on has maybe covered a thousand miles or so.
£250+VAT Sophie Alltoft
Post #367890 Fri Dec 28 2012 5:59pm
wilburn
£250+VAT
Hi Sounds, good. We are unable to collect as too far (we are in Whitchurch Shropshire).
Tyres on car at moment are Accelera Iota 275/40/ R20 106Y XL
I don't suppose you are able to supply with same tyre?
Also, how much for delivery please?
Thanks
Paul
Post #367892 Fri Dec 28 2012 6:09pm
duckworthparts
Site Sponsor
Hi Paul
free delivery for forum members,
unfortunately don't have any other wheel with that tyre on to swap it over with
could supply a new same brand tyre for £119+VAT Sophie Alltoft
Post #367895 Fri Dec 28 2012 6:13pm
wilburn
Hi Paul
Hi,
Ok, I'll take the wheel and tyre for £250 + vat plus free delivery.
I'll email you now.
Thanks
Paul
Post #367898 Fri Dec 28 2012 6:25pm
Bandit8
England 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I would just like to say that that thread was well done. Well done to duck worthparts for sorting that out at a lot less price than the stealers.
After reading some other threads, this was a pleasure to see that we all help out each other when needed.
Goup hug................. Embarassed It is what it is and I am what I am....
Post #367914 Fri Dec 28 2012 8:34pm
And not a mention of boobies! Thumbs Up 2005 Zambezi TDV6 - Gone but not forgotten
Post #367915 Fri Dec 28 2012 9:37pm
wilburn
£250+VAT
Two quick questions, is the tyre on the wheel a directional tyre? As it is to replace front nearside wheel.
At the moment I have the space saver wheel on which is a
255/50/R19 107Y Continental Cross Contact.
What psi should I have it set to?
Fronts are 'normally 33psi and back 36psi but not sure if the different size wheel/tyre should be at a different psi?
Thanks
Paul
Post #367960 Sat Dec 29 2012 3:55pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
The sticker on your drivers door tells you the pressures for the different sizes. I believe 33 is correct for 19s.
Post #367961 Sat Dec 29 2012 4:06pm
wilburn
Ah, so it does, I missed that it also list 19" next to 20" I just saw the reference to T175/80R19 122M at 60psi and thought - what the hell is that about.
Thanks Smile
Post #367969 Sat Dec 29 2012 5:26pm
Paddi
Agree it is great to see everyone working together and finding a solution for the IP. Only one thing a bit worrying - looks like he is going to end up with odd tyres on the same axle and worse still they won't be evenly worn. Doesn't this put a strain on the various expensive bits of transmission with their associated clutches and differentials and bits it seems no-one understands? Remember tyres are cheaper than new transmissions.Think I would be happier with two new tyres on that axle. Any technical experts like to cast some light here?
In the past on my Grand Cherokee V8 tried putting just new tyres on one axle and even that felt all wrong specially on full lock manoeuvering and there was a whine coming from somewhere at speed. Added another two new tyres to the other axle and suddenly all was transformed to silky smoothness. There was lots of conflicting misinformation on the relevant forums saying it was OK not OK etc. 2008 MY Java Black TDV8 HSE
Post #368037 Sun Dec 30 2012 8:43pm
