![]() | Home > Technical > Turbo replacement |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 ![]() ![]() ![]() |
Took car to an independent LR dealer today for a second opinion on the P132B fault after 1/2 hour of them thrashing it about with the auto logic machine plugged in they came up with the dreaded news - the turbo is stuffed |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4440 ![]() ![]() ![]() |
Comes out from underneath. Exhaust needs to be removed |
Pictures of the turbo removal, this is the first time I've done this so did it at my pace and maybe took more off than I need to.........
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
+1 |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 ![]() ![]() ![]() |
V. good write up with pictures Boost. My vehicle has just developed P0046 fault code which is 'Turbo/Super Charge Boost Control Solenoid A Circuit' according to my Hawkeye.
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
A brave man indeed - great write up too. Hope all goes back ok |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
I wouldn't dare attempt what you've done |
That's a different code to what I got, mine was P132B, but the description sounds exactly the same, I had mine checked by 2 different dealers before I took the plunge - I'm sure someone on here may be able to tell you or offer some adive. |
A lot of turbo suppliers insist on changing the oil supply pipe - why? No mention of this in the LR procedure for changiing?
Cam sensor, or a fuel rail pressure sensor |
Thanks Mikey, I was planning on trying that tonight..........
Nope, there is no gasket between the manifold and turbo. Great design ![]() May be worth mentioning that there might be an Engine Management software update, which sweeps the actuator through its full length of movement every time you start the car, to help prevent any future seizures ![]() |
Hi Boost, where did you get the turbo charge from and how much? I'm thinking of doing mine. Keep us up to date. Thanks 2005 RRS TDV6 HSE Java Black 2005 997 C2 |
I googled for them and fired about 6 E-mails off to different companies. various responses from repairing mine (seals & bearings - £195), reconditioned one (£395) then various prices for a full new unit, up to £1400+vat!!!
