Home > Wheels & Tyres > Profiles |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
Google "tyre sizes" and you'll find a selection of tyre size calculating tools which will give all the info you are looking for.
Mon Oct 29 2012 2:16am |
I wouldn't worry too much about the speedo being out a little bit, you will find its already out by 3mph on your standard tyres @ 30 mph and out by 4 mph @ 70. |
Mon Oct 29 2012 9:47am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
The car won't care what profile you fit just so long as you fit the same on each corner. The speedo / trip computer will read incorrectly but that's an issue for you, not the car 2012 SDV6 - it's missing a couple of cylinders
Mon Oct 29 2012 12:13pm |
You would be surprised how accurate the range rover speed limit is - it has the minimum required error (they all have to over-read so indicated 30 is a little less (10%) actual) Mike
Mon Oct 29 2012 3:55pm |
So why can't they get it spot on if they can manage to get it to read 10% over |
Mon Oct 29 2012 3:58pm |
They don't have to over-read but they absolutely must not under-read.
Mon Oct 29 2012 4:24pm |
Surely then, they could make it part of the service schedule then or make it part of an mot test, Its not that hard to do, they manage to do it for HGV's. I know many police forces allow the speed limit + 10% + 2mph max. |
Mon Oct 29 2012 4:34pm |
Thats very true and its thus its standard practice to carry 10% error Mike 2014 Facelift Discovery |
Mon Oct 29 2012 4:40pm |
Some of that is also about not being drawn into the marginal cases imagine not having a 10% error on your speedo and a strict speed enforcement + a few minor errors and you would need to be exactly correct on the speed Mike 2014 Facelift Discovery |
Mon Oct 29 2012 4:42pm |
One word: money
Mon Oct 29 2012 4:44pm |
I suppose when you explain it like that, i guess it makes sense |
Mon Oct 29 2012 4:48pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
with my new 20's my speedo is almost spot on (according to the radar speed display thingy in the village) RRS gone
Mon Oct 29 2012 4:55pm |
^^^ so it reads 70mph as you'rebombing through the village, the same as your speedo ON THE WAY: BMW F21 M140i
Mon Oct 29 2012 5:40pm |
*just* 70? RRS gone
Mon Oct 29 2012 5:43pm |
