![]() | Home > Technical > P132E Fault code |
After a spirited drive back from the NEC caravan show at the weekend I was happily tracking |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
yup, my indie put in on a ramp, and sprayed silicone grease onto both of them, its not done it since 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
There is a modified rod and bolt available. It would be worth freeing it off first, and if its OK, have the new rod fitted.
Well it finally did it again on Saturday. (P132E error recorded, I'm assuming the "E" refers to which turbo it is?)
Both can be done with turbo's in situ |
Ideally, yes.
TEV Member Since: 27 Aug 2013 Location: london Posts: 2 ![]() ![]() ![]() |
Thanks Mikey fingers x all done .. |
Did it fix it? |
mees Member Since: 17 Jul 2009 Location: bru Posts: 45 ![]() ![]() ![]() |
Hi have the same problem and the same fault.
Went to the dealer in jena germany
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Would an MY2010 TDV8 have the modified rod and bolt already fitted or did LR never update them? I don't have a problem but I am keen to avoid one. |
Mine is december 2009, so MY 2010 |
brgjohn Member Since: 27 Apr 2016 Location: somerset Posts: 7 ![]() ![]() ![]() |
Mine is an '05 tdv6 , how do you access the actuator rod?, taken off the heatshields, looked from top and underneath, can just see one end ! |
