Home > General > Waking car from sleep mode if unable to reach passenger door
muddywheels
Milk Float Man
Oldgeezer has had an issue with his fl2 and got me thinking Shocked
http://www.freel2.com/forum/topic13457.html
oldgeezer wrote:
My FR2 was parked in my Garage tight against the wall and had gone to sleep !
Key entry is passenger side but the walls in the way. I usually leave the window open but had forgotten this time.
I don't want to break the glass and currently had to pad the wall with foam and jack the car up and drag across the garage
Has anyone had this problem/does it affect the RRS Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #359579 Sun Oct 14 2012 11:16am
SRE
Spain
Any chance you get under the car and reach the Starter motor terminals, if so connect battery charger or slave battery to the main terminal and the other lead to any earth point In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #359586 Sun Oct 14 2012 12:30pm
flydive
I had my RRS parked for full 3 month, remote worked fine. '08 RRS TDV8
Post #359597 Sun Oct 14 2012 1:34pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
unsurprisingly the car is not by design meant to flatten its battery over just a few weeks
check for shorts, or things being left on. Some people recommend setting the suspension to access mode in the mistaken belief this stops the computer waking up and adjusting itself. Again by design it shouldn't be doing this (unless parked on a ferry Whistle )
appreciate this doesn't help you get into the car in the current state - my advice would be to get another RRS owner to drag it out with a tow rope? Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #359647 Sun Oct 14 2012 11:47pm
SRE
Spain
Not easy when it's stuck in Park Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #359654 Mon Oct 15 2012 8:38am
muddywheels
Milk Float Man
Op jacked up car and dragged it over to gain access - no easy feat with a bad back and ludicrous that he should have to do this Rolling Eyes
In the past he has left car connected to charger when not in use Sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #359664 Mon Oct 15 2012 9:02am
