![]() | Home > Maintenance & Modifications > upper glovebox annoying rattle |
eskimorob Member Since: 05 Aug 2010 Location: Gravesend Posts: 7 ![]() ![]() ![]() |
Yes mine does that, I find if I leave it open it doesn't do it.
My glovebox was making an annoying buzz. Looked as if it was caused simply by the lid not closing tightly enough so there was a tiny bit of movement. Didn't seem to be any adjustment on the latch and dismantling it to put in a packing piece looked too difficult. In the end I just stuck two 1cm long pieces of sticky backed rubber draught proofing strip http://www.diy.com/nav/build/insulation/dr...908050(one either side of the latch).
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
I have this problem too. It seems that the latch mechanism itself is what is causing the rattle. I was considerig doing the same as what Paddi has done but there must be a slightly longer rubber bung out there somewhere that will fit?? |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 701 ![]() ![]() ![]() |
Mine too! Java black 2006 |
vic_ster51 Member Since: 21 Sep 2012 Location: east anglia Posts: 28 ![]() ![]() ![]() |
Yeah its seems that it dont fit tight tight as such c ebb |
Has anyone got a BMW? If so can you please check your glovebox and see if the rubber plug is slightly bigger than the RR one?
UK Guy Member Since: 28 Nov 2010 Location: Staffs Posts: 149 ![]() ![]() ![]() |
I had this driving me mad for 6 months before I figured out how to fix it.
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 ![]() ![]() ![]() |
No problem with mine, not even on the last one. Then again it is so full usually it can’t move. So thanks to my partner for storing gloves, 3 pairs various colours; scarves, 4 varying styles; and various other garments to cover every eventuality. But certainly never rattles. |
