Home > Maintenance & Modifications > DIY twin iPOD lead installation
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
I decided to go a bit DIY for fitting my iPod in my 2005MY RRS.
More specifically, I use and iPhone with TomTom for navigation, so really wanted two iPod connections in the car. One by the windshield for navigation and when I wasn't using that, one in the glove box for music from my iPod Classic.
So, I bought two of these from Amazon, the same is available from Apple but in white, these were black and fitted better with the interior.
http://www.amazon.co.uk/gp/product/B004SBB...01_s01_i00
I also got a griffin twin usb charger
http://www.amazon.co.uk/gp/product/B0042B8...01_s00_i00
And a small DPDT switch from Maplins, along with a 3.5mm stereo jack and a 4xphono planel (2 left + 2 right phono sockets)
The 3.5mm jack is needed so create the ground connection to the AUX input. For some reason (probably to avoid interference), the car's ground and the aux ground are not the same. Plugging the 3.5mm jack into the AUX input makes the ground connection. Without it, you'll have no sound. So I've cut all the soldering tabs off mine, reduced the size of the plastic cover and leave it permanently plugged into the AUX jack.
A colleague of mine who lives in the US also got me an iJet remote control (http://www.buyijet.com/) which enables me to leave the classic in the glove box and remotely pause/play and skip next/previous. If you decide to go this route, make sure you get one with a dock connector that supports full passthrough so you get the audio out of the dock connector, and power from the iPod lead into the iPod itself.
A quick word of warning, much of the RRS's dash is clipped together and sometimes, when pulling a piece of trim off, clips that should come with whatever trim you're releasing prefer to drop behind the dash or somewhere equally annoying to get to. A magnetic pick up wand is useful, but there's a chance you won't recover all the clips, so a few spare might be a good idea if you want to keep your dash rattle free.
Start with a complete dashboard
Remove stereo surrounds, then fish for clips
Pull gearbox knob off (no clips here)
Remove terrain response, park brake, etc... housing (lots of connectors underneath that need to be removed)
Fish for clips
Remove the remainder of the floor console, should be one screw near the fridge, two near the stereo, the rest is clips
Fish for clips
Remove driver's side trim as well as the vent to the left of steering wheel. All clipped in place, needs a sharp tug.
Fish for clips
Remove air vent (two screws)
Remove stereo (4 screws), the switch panel above will also need to come off for the radio to slide out (2 screws) as will the HEVAC controls panel (4 fiddly screws some of which you can easily loose)
This is the connector which carries the AUX input to the stereo, C2115.
Black is the audio ground (not the car's ground), Blue is Right, Red is Left which is somewhat counter intuitive since most audio cabling is red for right and white or other for left. Wouldn't be a Land Rover if standards were adhered to !
Cut all three
New loom with DPDT (Double Pole, Double Throw) switch which has ON-OFF-ON positions.
This switch switches the input from one iPod to the other. The middle position is off and enables the rear AUX input to be used without interfering with the iPods. Essentially, the left/right from on of the phono panels goes to the lugs on the left of the switch, the left/right from the other phono goes to the right lugs on the switch, and the middle lugs are connected to the stereo's AUX inputs (Blue, Red, Black).
Switching loom now soldered back into the main loom
Power to 12V socket piggy-backed off the original one.
iPod Lead run through gaps
Now onto the passenger side
Remove air vent
Fish for clips
Pull the inner part of the upper glove box, for this you'll need to remove the side trim that runs along and down the right hand side of the footwell. Also, if you open the glovebox, you can get your hand behind the inner and push it firmly towards you.
Fish for clips.
Drilled hole and put a grommet on the upper right hand side of the glovebox to run iPod wire through
Run iPod cable through to stereo aperture
Plug iPod phono connectors into the phono board
Plug twin usb charger into 12v socket, and then usb plugs from the iPod leads into it.
Drill small hole near cigarette lighter socket and secure switch
Finally hopefully this drawing will help understand the wiring side of things, the orange part is meant to represent the DPDT switch.
"Roads ? Where we're going there are no roads." Back to the future.
Post #356094 Sun Sep 09 2012 9:41pm
I doff my cap to you Sir Froggy, Bow down Thumbs Up
I think it's fair to say I don't have the 'technical skills' to take the dashboard apart, let alone incorporate something like this, even if I wanted to. Rolling with laughter ON THE WAY: BMW F21 M140i
Post #356104 Mon Sep 10 2012 8:35am
mrfrog
I've looked up the part number for the clips that tend to go wayward: FYC500040, CLIP, STEEL.
There's a different clips (x4) under the terrain response piece of trim, but I can't find that anywhere, it's more like a folded flat spring type of clip.
Post #356123 Mon Sep 10 2012 1:31pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Is the volume still lower on the aux setting connecting this way,or has it rectified that?
Steve
Post #356143 Mon Sep 10 2012 3:39pm
mrfrog
Should be exactly the same, I've just tapped into the wires closer to the head unit, there are no electronics between the AUX jack and the head unit, just wiring so no reason for it to be any different.
Post #356158 Mon Sep 10 2012 6:39pm
mrfixit
So have you not noticed a difference in volume when you switch between Aux and radio or cd?
Post #356167 Mon Sep 10 2012 8:29pm
mrfrog
I haven't used the radio or CD since so can't answer I am afraid, but nothing I did would have improved or made it any worse.
Post #356172 Mon Sep 10 2012 10:02pm
mrfixit
The aux input volume is lower on mine,and others have mentioned this as well.
Post #356178 Mon Sep 10 2012 10:30pm
mrfrog
Tried it this morning and aux is lower than the radio on mine too. I guess it's because people could plug all manner of things in the jack, particularly output from the headphones of their mp3 player which is higher level (more volts) than an AUX output from the iPod's dock connector or other "proper" auxiliary output. This in turn could lead to distortion when fed headphone outputs if they had set the input to "official" aux levels. Hope this makes sense.
Took a few more pictures this morning
iPod classic in glovebox
iJet remote receiver in dock connector
iJet Remote
iPhone on windscreen mount
"dummy" jack in aux socket behind armrest
Post #356192 Tue Sep 11 2012 8:30am
mrfixit
Cheers,didn't think it would have sorted the volume issue.This was my iPod/iPhone solution.
http://www.rrsport.co.uk/forum/topic20919.html?highlight=
Post #356246 Tue Sep 11 2012 5:55pm
mrfrog
Very sweet Mr. Green might have to consider an upgrade, although I like the sat nav in front of me, rather than the side.
Post #356247 Tue Sep 11 2012 6:35pm
mse
Ive not looked - certainly on older models - but cant you set a range of those preset volumes, like the mobile phone level etc.
Its not a normal menu on pre 12MY you have to go an odd way to find it i cant recall - does it have an aux level in there? i dont know, but worth a look Mike
2014 Facelift Discovery
Post #356258 Tue Sep 11 2012 8:49pm
mrfrog
Google doesn't come up with any tricks for changing the AUX volume. Someone on a different forum suggested turning Logic 7 off, but that made zero difference to mine.
Post #356283 Wed Sep 12 2012 9:52am
mse
I wouldnt have search on google and the logic 7 thing, well i would say thats rubbish.
Search on here Mike
Post #356285 Wed Sep 12 2012 10:38am
mse
here you go...a proper search here and got it...im not saying its going to work for you: (BTW - look at the bottom for pre 2009 cars)
Quote:
Try looking at Page 283 of the Owners Handbook.
If you hold down the "tone" button (muical note) on the dash, the volume menu comes up allowing you to set Nav, Phone etc volumes individually.
and
Quote:
Audio level settings VOLUME ADJUSTMENT
Sustained exposure to high sound levels can
damage your hearing.
To access the volume set up menu,
press and hold the Tone hard key
until the volume set up menu is displayed. The
soft keys to the left, allow you to choose a
setting to adjust (AVC, INFO, NAV, PHONE and
VOICE). The boxes to the right of the soft keys
show the values currently set for each option.
The bar graph and the +/– soft keys are used to
change the settings and show the changes.
Note: If no change is made within ten seconds,
the volume set up menu will disappear.
Automatic Volume Control (AVC)
Automatic Volume Control adjusts the volume
level as the vehicle speed increases. This
compensates for the increase in noise at
increased speeds.
From the volume set up menu, touch the AVC
soft key to display the settings for AVC.
The bar graph represents the amount by which
the volume level may increase. If the smallest
bar is selected, the AVC function will be turned
off. In this state the volume will not increase
with vehicle speed. The remaining bars (from 1
to 9) will increase the volume level up to the
maximum level selected.
To increase the level of volume change, press
the + soft key. Each press will select the next
bar to the right, up to the maximum (9).
To decrease the level of volume change, press
the – soft key. Each press will select the next
bar to the left, down to the minimum (1). A
subsequent press of the – soft key will switch
AVC off.
Information announcements
Press the INFO soft key from the volume set up
menu, to adjust the volume level for radio
announcements, such as news broadcasts and
traffic announcements on RDS.
To increase the volume level, press the + soft
key. Each press will select the next bar to the
To decrease the volume level, press the – soft
Navigation guidance
Press the NAV soft key from the volume set up
menu, to adjust the volume level for navigation
guidance messages.
Telephone volume
Press the PHONE soft key from the volume set
up menu, to adjust the volume level for the
telephone.
right, up to the maximum (25).
left, down to the minimum (5).
According to the Topix manual for a 2009 model car - Pages 276-278 there is the same facility with "pre-facelift" cars but it's accessed slightly differently.
 Mike
Post #356286 Wed Sep 12 2012 10:40am
