![]() | Home > Technical > Parking sensors suddenly don't work... |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
one or more of the sensors are away mate
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 ![]() ![]() ![]() |
I had this, Land Rover replaced the loom |
panpicker Member Since: 27 Dec 2009 Location: buckingham Posts: 38 ![]() ![]() ![]() |
i have the same problem started about a month ago and now had loss of gears with the dash reading Transmission failure after checks have been told the alternator needs replacing. |
Do a Search...
Sirwacko Member Since: 22 Mar 2012 Location: Near Blackpool Posts: 74 ![]() ![]() ![]() |
Thanks for the advice... I did try that hence the post ![]() Think I need to find out which is at fault and purchase hopefully just 1. Cheers x5pea your a star! RRS Dynamic |
Sorry, didn't read your first post properly to realise that. ![]() ![]() ![]() Will be careful the next time. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Sir Wacko 1, Bobby 0 |
Katrina999 Member Since: 23 Sep 2011 Location: Ayrshire Posts: 13 ![]() ![]() ![]() |
Hi I had the same problem trip to the dealers discovered one of the sensors and a bit of the wiring loom had corroded afraid it looks like it might be the same for you |
neo1 Member Since: 21 Oct 2010 Location: Durham Posts: 72 ![]() ![]() |
mine is doing the same one of the 4 faults my piece of |
redrob Member Since: 07 Jan 2012 Location: near St Aines Posts: 39 ![]() ![]() ![]() |
Get the Mrs to put it in reverse whilst you stick your head down under the car to listen.............
Hi we had our sensors replaced under the warranty we had taken out . I think initially I saw the paperwork it was around the £350 mark.
Katrina |
