Home > Tips & Tricks > Access Height - Set to Automatically work? |
I try to use everything occasionally just to make sure it's still working and to keep it freed up.
Fri Jan 13 2017 12:19am |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 461 |
Hi, Turn off "Auto". It turns climate into a conventional heater , stops using the compressor and reduces the engine load. Scrumps. Somerset - Where the apples do grow and the cider do flow! 2021 Defender 90 D250 HSE in Tasman with white roof. 24MY D300 AB - Verasine Blue - 😀 19MY SDV6 AB - Byron Blue - Gone 17MY D5 SDV6 HSE - Firenze Red - Gone 16MY SDV6 AB -Aruba Silver - Gone 13.5MY SDV6 "HSE Black" - Baltic Blue - Gone 10MY TDV8 HSE Galway Green - Gone 14MY D4 HSE in Scotia Grey - Gone 05 TD5 D90 CSW in Cairns Blue |
Thu Jan 19 2017 11:53pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1135 |
+1 I also lower my D4 when I have parked. This, together with gathering my wallet, keys, etc., lets the turbo cool down a bit before I switch off. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Fri Jan 20 2017 12:00pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Yes it is less stressful on the handbrake, gearbox parking claw etc. etc. |
Fri Jan 20 2017 12:52pm |
NickyN Member Since: 14 Jun 2019 Location: Cheshire / Anglesey Posts: 1 |
I may be going mad but having stopped the car and forgotten to lower to access height for the dog, when I press the lower button with the ignition on ( engine not running ). The car actually rises.
Fri Jun 14 2019 5:08pm |
Tallchap Member Since: 09 Oct 2019 Location: Maidenhead Posts: 20 |
I am a newbie, but I believe the LR button on the key can be coded to several features - one of which can be to lower the suspension to access height, or to raise it. Once you have ‘coded’ the button, you then press and hold the LR button and lock button to raise, or LR button and unlock button to lower.
Tue Oct 15 2019 9:24am |
Sorry, page 39 |
Tue Oct 15 2019 9:26am |
nil07 Member Since: 05 Apr 2015 Location: london Posts: 115 |
I believe there is a button under the steering column which does this if it either pressed or not ...can’t remember which N
Tue Oct 15 2019 12:59pm |
