Home > General > Cut out while driving then starts but rough no acceleration
Page 1 of 5 12345>
timcom0
My 2.7 TDC6 whilst driving home last week decided to die, when i pulled over although it would startt was idling like there was a deisel blockage of some sort, however took into the dealer and they say no faults are registering but are going to check Cam Sensor does anybody have any ides?
Post #287774 Wed Feb 02 2011 4:58pm
EGR Valve sticking? common fault
Ady
Post #287795 Wed Feb 02 2011 8:44pm
timcom0
LR left a message that they can't find the problem so are removing more to check camshaft sensor fully is this in line with checking EGR?
Just that they started yesterday afternoon looking for fault, so assume going to be a expensive find either way.
Post #287807 Wed Feb 02 2011 9:46pm
I think it a case of process of elimination until they find the fault seen as it hasn't thrown any fault codes up
Ady
Post #287836 Thu Feb 03 2011 7:56am
GTSteve
England 2008 Range Rover Sport TDV8 HST Java Black
Had the same fault on my Discovery 3 TDV6, Faultmate confirmed it was the EGR valves, so I bought some blanking plates had them fitted the car was right as rain after that, and fitting blanking plates was a lot cheaper than the EGR's would have cost. BLACK RRS HST 3.6 MY08
Post #287925 Thu Feb 03 2011 9:32pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Blanks are only possible on a pre 2007 model year!
Post #287932 Thu Feb 03 2011 9:58pm
timcom0
Hi, had a call from Guy Salmon today after 3 days looking at my RRS to tell me the engine has gone.
It's on a 57 with 92000 and as I mentioned before not asingle warning light or hint that any problems only when it died on dual carraigeway, just getting the whiskey out, till I go and see them Monday
Post #287997 Fri Feb 04 2011 6:44pm
What Question Someone has stolen your engine whilst in their possession?
Post #288013 Fri Feb 04 2011 9:27pm
timcom0
I wish, no now say knackered and need a new engine? Twisted Evil
Post #288026 Fri Feb 04 2011 11:36pm
1JBS
Not the first time I have heard this, what has actually gone wrong with the engine?
Post #288029 Sat Feb 05 2011 12:27am
timcom0
At this moment they cant say just say I must have drove without oil, umm don't think so
actually checked the oil 3 days before and didn't need any, so don't know what to do now
but going down on monday to find out why no computer messages no oil pressure light and what part of the engine actually gone
Post #288073 Sat Feb 05 2011 3:19pm
timcom0
Anyone any ides as the car starts up as it did when I dropped it in but runs rough with no acceleration
when you push the pedal, I find it unbeleivable that a car of this nature can just stop without warning.
Post #288074 Sat Feb 05 2011 3:22pm
I'd get a second opinion
Ady
Post #288100 Sat Feb 05 2011 7:25pm
timcom0
Just thinking that but where do you go? Are they all going to stick together or do I use a specialist
or contact nearest LR Dealer
Post #288174 Sun Feb 06 2011 11:06am
Sounds like your timing has slipped ask around try to find an independent LR specialists ask him to give it the once over or pick his brains tell him the symptons and ask your dealer to be a bit more specific of the failure. Good luck
Ady
Post #288194 Sun Feb 06 2011 3:32pm
Page 1 of 5 12345>
