![]() | Home > Maintenance & Modifications > To Blank or Not To Blank, That is the question? |
The Range Rover Member Since: 25 Jan 2010 Location: Whitburn Posts: 30 ![]() ![]() ![]() |
Hi Guys
I have a Tdi300 TDi engined Defender that was delivered in 1996 with a cat when they were an optional extra. When the downpipe corroded and the cat was not working well the local non-franchised LR specialist I use advised non-replacement of the cat and removal and blanking of the EGR as leaving them in can cause problems with the ECU later down the line. So Cat was removed, EGR removed and blanked and the Lamba probe was removed result was a smoother running (does that matter in a Defender?) quieter engine and better mpg as the engine can breathe better, so if you have them removed take everything out and disconnect the electronics to save weird electrical problems with the ECU still thinking there is a a Cat and EGRs and it sails through the MOT with ease on the emissions front too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Did mine couple of months ago. Now smoother 1-2 mpg more better pick up. Cost for kit from bells autos and fitting at garage just over a £100. One EGR valve replacement way more than that.
s1ras Member Since: 02 Sep 2010 Location: Windsor Posts: 36 ![]() ![]() |
Hi guys, my egr valves got clogged up on my RRS TDV6, i had the blanking kit fitted, it now drives so much better, and im getting better consumption! and at least theres 2 less things to go wrong now, i recommend it! |
iz6byo Member Since: 26 Dec 2008 Location: Italy Posts: 109 ![]() ![]() |
replaced with BAS kit!!!!!!!!! |
Last night my Beloved RRS gave me the reduced power and dreaded black smoke!!!!
craneboy Member Since: 17 Feb 2011 Location: North Wales Posts: 111 ![]() |
Did mine just over a month ago and have to agree with the above.
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Just a reminder for everyone reading, EGR blanking without error lights is only possible on 2006 model year and earlier TDV6s. 2007MY onwards are Euro 4 emissions standard which mandates the illumination of an error light when there's no EGR flow |
1000000000000000000%.....
I'm having a run up to bellauto's in the morning, i might just get the blanking kit while i'm there. |
Sure!!!! But he has a my06.... On my07 the dashboard shows some error.... |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
So what do you do to blank a post 07My and not get errors showing up???
