Home > Maintenance & Modifications > Dynamic response actuator leak??
Sizzle TDV8
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
It looks like I have a slight leak coming from the ram on the rear stabiliser bar.
I have heard that if the filter gets blocked on this system this can cause it, or are there replaceable seals on the ram that degrade over time (grit ingress etc)??? Any advice and diagrams greatly appreciated.
It's a 2007 TDV8, just out of warranty, typical.....
Thanks.
Post #262004 Sun Apr 04 2010 9:35pm
Sizzle TDV8
Anybody?? 2007 RRS TDV8 Stornaway Grey with lots of smiles..
2007 Audi A4 2.0T Cabriolet
Missing - 2008 Suzuki GSX-R 750
Post #262227 Wed Apr 07 2010 8:03am
dadanek
Czech Republic 2007 Range Rover Sport Supercharged Java Black
I have the same problem, luckily it happened to me under warranty... RANGE ROVER, MORE THAN A CAR, LESS THAN A KITKAT
Post #262238 Wed Apr 07 2010 10:58am
Sizzle TDV8
How many miles had you covered??? And what needed replacing??? 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #262255 Wed Apr 07 2010 3:54pm
Bob.
Sadly I don't believe that LR list any spares for the actuator. How big a leak is it? If it is just a wetness on the piston it probably isn't an issue. If foreign matter has got into the system it could be a degrading pump rather than dirt from outside. Have you checked the filter in the reservoir?
This is a cross section of the actuator.
Hope this helps.
Post #262312 Wed Apr 07 2010 8:50pm
Sizzle TDV8
Ohhh my god, my stealer just called me up to say it will be £1688. . . . . . Just fell over when she told me the price. The ARB is £860 on its own!
Thanks Bob, it is leaking from the actual ram piston (leaking from somewhere of part number 2). I expect a slight misting of oil due to how it works, but this is an actual drip of oil than is ruining my drive.
I haven't checked the filter but I'll do that in the morning, is it just placed into the reservoir??
The annoying part is that this vehicle has already had the rear ARB replaced back in November 2008 (under warranty)!!! Surely this isn't a common thing to keep failing.
So, 1 day out of warranty and Land Rover are only willing to pay 25% of the cost. . . . . Totally disgusted.
Any suggestions?? Thanks in advance. 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #262342 Wed Apr 07 2010 10:23pm
Sizzle TDV8
Bob or anyone else care to elaborate, is the filter readily visible when you take the yellow cap off the dynamic response reservoir..... Only as I can't see anything!! 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #262546 Fri Apr 09 2010 4:46pm
Sizzle TDV8
Anybody????
Where is the filter located???? 2007 RRS TDV8 Stornaway Grey with lots of smiles..
Post #262733 Sun Apr 11 2010 6:11pm
