Home > Technical > Fuel Filter Where and how!!
TT
Hi
Where can i find the filter and change it.
2005 RRS TDV6
Pictures will help!!
Thanks for any help
Post #228228 Mon Jun 15 2009 5:19pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
I am sure Bobby will be along soon with all the info required Thumbs Up
Post #228243 Mon Jun 15 2009 8:00pm
Bobby
I found this....
hope its what you're looking for Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #228259 Tue Jun 16 2009 1:29am
TT
Thats fantastic. Thanks very much. Any idea how to bleed it. I think its something to do will pumping the throttle with key in position 1. Does that sound right??? Confused
Post #228262 Tue Jun 16 2009 7:23am
Bobby
I'm not sure how that's done but I believe you've got to install a special tool with a valve into the fuel rail. This tool is attached to a hose and you need a suitable container at the end to collect the spillage.
You then turn the ignition switch to ON for 25 seconds. The fuel pump will work and fuel will spill from this hose. When the fuel coming out the hose is air-free, you close the valve. If not, you go through this procedure again until the fuel is air-free.
Please reconfirm the above with someone in the know. Malaysia Boleh!
Post #228271 Tue Jun 16 2009 8:47am
mr_moped
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Special Tool - That's a joke, a normal tyre valve removal tool does the job!
Post #228366 Tue Jun 16 2009 5:09pm
Bobby
I wasn't trying to be funny, not done this myself but just passing along what I had heard. Sad Malaysia Boleh!
Post #228389 Tue Jun 16 2009 9:09pm
mihakrapez
Slovenia 2006 Range Rover Sport TDV6 HSE Java Black
You saved my day. Thanx a milion Cool
Post #229733 Mon Jul 06 2009 10:00am
