![]() | Home > Maintenance & Modifications > Temporary brake failure |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 ![]() ![]() ![]() |
Also if you took it back with a known "latent" defect in the brakes your insurers wouldn't be terribly happy if you had an accident 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 ![]() ![]() |
I've seen a similar problem before on a td5 disco , i think.
mercuryl Member Since: 07 Oct 2008 Location: Sussex Posts: 195 ![]() ![]() ![]() |
It's going back to Guy Salmom in Portsmouth. Land Rover Assist are picking it up shortly - and arranging an Enterprise rental car - to arrive this evening so they say. Don't know what it'll be - probably a Focus or Mondeoo I guess?
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 ![]() ![]() ![]() |
We got a FFRR TDv8 from Enterprise today, courtesy of LRA. The secret is that when they bring you some wretched Vauxhall thingy you must stamp your feet, beat your fists on the ground and threaten to scream and scream and scream until you are sick. They will then bring you a "proper" car ![]() Disco 4 TDv6 HSE Ipanema Defender 90, 200tdi CSW |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
My experience of LRA was like for like or better policy - had FFRR both (or more ??) times |
ROB.T Member Since: 21 Nov 2006 Location: LEICESTER Posts: 10 ![]() ![]() ![]() |
Hope that this is not a 'trend', mine went in for the same problem two days ago, damn scary when it happens but only happens in the morning. Dealer waiting for 'none return valve' which is in the 'break pipe'. Also mentioned to dealer about 'knocking' from front end, apparently they found something loose underneath that wasn't tightened by Land Rover on assembly of vehicle. |
Tim, hope you had a good laugh at my expense! let's not forget we are trying to help each other out here and not correct grammar, this is not an English exercise after all.
Here here. Yes Tim, I don't see the point in making fun of someone ... especially when your jokes are not funny. Just makes you look childish. I've been mad for flipping years, absolutely years, over the edge for yonks. |
richh Member Since: 15 Feb 2009 Location: england Posts: 9 ![]() |
hi guys we have had a couple of d3s do this, its when the vaccuum pump on the back of the engine has aspirations of been an oil pump, the seals go bad and engine oil leaks into the pump and is then cleverly sent to the brake servo via the pipe that runs into the brake servo box (it has a ful pipe style connector before it dissapears into the top of the box) check the servo, i bet its full of engine oil. hope this helps, Richh they all do that! |
