Home > Technical > Battery Charging
Frozen of Wiltshire
United Kingdom 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Battery Charging
Hi all,
First post from a new member, so apologies if this has been answered before and I haven't seen it. I've just acquired a 2007 Range Rover Sport TDV8 and want to charge battery as it's been idle for a while (before I got it). Can anyone tell me if it's ok to use a CTEK XS3600 charger with it's cigarette lighter socket adapter connected into the 12v socket in the boot? I've used this on my previous car with no problem, but nobody at the land rover dealer seems to know. They also said something about a calcium battery being in it and didn't know whether my charger would work at all?
All info/experiences greatly appreciated.
Thanks Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Defender 90 TD5, Tonga Green
Post #204242 Thu Jan 08 2009 2:01pm
Bobby
I wouldn't do that. There's too much electronics involved.
Its recommended to always use an approved constant current charger, designed for lead-calcium batteries. DO NOT use a fast charger, as permanent damage to the battery may occur.
On the other hand, since you've just acquired it, why not just take the vehicle for spin around the village? You'll enjoy the drive and also allow the battery to be charged! Wink Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #204249 Thu Jan 08 2009 2:21pm
Pelyma
The Ctek is fine for lead calcium batteries, but I don't think you can charge through the power outlet. Porsche Cayenne S Diesel 66 Plate
Post #204250 Thu Jan 08 2009 2:25pm
Frozen of Wiltshire
Thanks for the quick replies - car is now connected and charging with the clip-on cables on the battery and seems to be doing it's thing ok.
Regarding the 12v connector, most people were a bit nervous about using the cigarette socket on my other car too (boxster) but after asking around a bit i found out that porsche did exactly this themselves with the same type of charger - and it worked fine. So nervousness aside, I wonder if any of the Land Rover engineers/tech people know definitively if this is ok on an RRsport also or not?
Playing it safe for now and directly connecting to battery which works ok, so now just curious about the answer rather than desperate!
Thanks again. Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Post #204253 Thu Jan 08 2009 2:55pm
flydive
The aux sockets are switched off without key.
You have to connect the charger directly to the battery. '08 RRS TDV8
Post #204254 Thu Jan 08 2009 2:56pm
MAW
And remember the battery is covered under warranty if you do have 'problems'....
Post #204344 Thu Jan 08 2009 5:01pm
Frozen of Wiltshire
battery charged ok
Hi all,
thanks for the advice, and thought I'd leave an update in case anyone else asks in future. Battery charged just fine with clip-on leads. CTEK-XS3600 works fine with RRS lead calcium battery. Also charged ok in very cold weather (-5) with no problem. Range Rover Sport TDV8 HSE, Buckingham Blue with Ebony Black
Post #205110 Mon Jan 12 2009 4:09pm
Good to know - thanks for keeping us updated! Very Happy
Post #205114 Mon Jan 12 2009 4:17pm
Frozen of Wiltshire
Update below for anyone interested. Have now had my CTEK charger connected to my RRS by local LR dealer so it's probably the most sensible way of doing it. CTEK charges with clip-on leads, or more sensibly with a pigtail lead that you screw onto the battery terminals and leave there to connect onto - this has no spark risk and is tidier, and what I normally use on other cars. Pic below shows RRS battery box (under plastic cover under bonnet) - green arrows show location of positive and negative terminal attachment points for pigtail, and blue arrow shows other end of pigtail where charger attaches. Whole thing sits nicely under battery box lid and makes attach/detach of charger safe and simple.
Post #210784 Tue Feb 10 2009 6:57pm
tornado34
2006 Range Rover Sport TDV6 HSE Zambezi Silver
Battery box / cover - I don't have one Big Cry
Could someone post a photo of theirs (off the car) and maybe post the LR part number from it so I can find one online.
Think it's probably a good idea to keep this clean and dry Thumbs Up
Post #258113 Thu Mar 04 2010 2:13pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Frozen I don't have a battery there Shocked mine is on the other side of the car.
Seemingly there is a 12V live connection on the 13 pin trailer socket and I was going to use that to keep my battery charged through the winter, I have an OptimateII that I got for the bike but never used as I am able to keep it charged with a solar panel. The solar panel can't keep up with the battery drain in the RRS if it is anything less than fully charged. Next time I'm in Hasselt I'm going to ask about the battery drain while the car is switched off. Sons of dogs come hither and get flesh
Clan Cameron
Post #258114 Thu Mar 04 2010 2:37pm
Bob.
T34 - Description is "Lid - Battery Box, Battery, Cover LHD - part no. DWN500022.
It's a mirror image of the one over the brake master cylinder on the other side of the engine bay - or is that missing too?
If that's missing you have real problems as you have nowhere to keep your cod & chips warm on the way home from the chip shop.
Post #258155 Thu Mar 04 2010 9:50pm
