![]() | Home > Technical > Radio on for 4 hours = flat battery is this right ? |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
IIRC Radio switches off after 20 - 30 mins w/o keys in to prevent flat battery...
OK ignore warranty Q - just seen other post ... |
McBunny Member Since: 18 Sep 2008 Location: South Posts: 679 ![]() ![]() ![]() |
That definitely does not sound right. The battery should do more than four hours I think.
jammy Member Since: 04 Jul 2008 Location: East Midlands Posts: 46 ![]() ![]() ![]() |
Thanks McBunny, that's what I thought, the battery should last more than 4 hours. The radio was still working but I got the impression the battery was almost flat.
Hm, that sounds like a flat battery.
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
I used the RRS as a torch once when fixing some fencing in the field, it was an emergency and I remember it was freezing cold, the lights were on full whack for some 3 hours......alas the battery was dead, but the radio still worked!!
That's funny so in case of a flat battery if the car won't start you can at least listen to some music to chear you up while waiting for the mechanics. Clever! |
Mine is a supercharged ![]() ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
If the s/c makes you cry maybe you want to change cars and drive something more economical? |
Where would the fun be in that. I would have nothing to moan about....nothing |
