Home > Technical > Diff noise! |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2834 |
The boys on the D3 site have posted this http://www.disco3.co.uk/forum/topic24503.html
Wed Nov 12 2008 11:41am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
I am having to have a new rear diff fitted soon Zilch. I have vibes and a thrumming noise on some road surfaces which has been diagnosed as a rear diff issue by LR technical. I will let you know how it goes after the new one is fitted.... |
Sat Jan 24 2009 2:49am |
BKHK please do, mine is out of warranty in the next 8 weeks, so if it does break, now i think is best. I do get a noise on some road surfaces and put it down to the surface itself, last time the dealer put it down to wheel balancing. I no longer get any vibrations from the wheel, just the whirring noise..but not always baffling Another Pommie Bar Steward down under MY20 Defender 110 SE P400 Eiger/Ebony MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre |
Wed Feb 04 2009 10:30am |
On a warranty check yesterday, a LR specialist put it down on my TDv6 to worn front control arm bushes. He believes that this is causing undue "bounce" on the front end, the tyres are then wearing unevenly, and therefore cause a rumbling affect on the road, they have seen this on a number of Sports and D3's of around 2 years plus age. They explained that this means that the road noise can be exaggarated dependent on the surface.
Tue Mar 10 2009 11:40am |
cocoza Member Since: 23 Sep 2009 Location: Dubai Posts: 1 |
Hey! Noticed your location so you maybe able to help.................
Sun Sep 27 2009 5:22pm |
antrrs Member Since: 04 Apr 2008 Location: Bolton Posts: 17 |
I've got a severe rumbling noise from the front end on mine (tdv6 07) I dont know what diff noise sounds like but I've replaced the front discs/calipers and all four wheels and it's made no difference.
Sun Mar 07 2010 11:52pm |
The Range Rover Member Since: 25 Jan 2010 Location: Whitburn Posts: 27 |
Hi All
Mon Nov 29 2010 10:22am |
No the 1700-2100 rpm noise is not diff related. It is more likely to be engine mount related.
Mon Nov 29 2010 12:34pm |
Stefan6666 Member Since: 21 Apr 2010 Location: Miami, Florida. Posts: 10 |
seems like I also have a diff problem.
Tue Dec 07 2010 1:44pm |
vnitos Member Since: 03 Nov 2010 Location: pretoria Posts: 31 |
get them to replace the entire diff at THEIR COST. my 2007 disco3's rear diff was replaced at 57000kms and the front at 71000kms. the front diff is leaking AFTER BEING REPLACED BY A LR DEALER! When I took it in for a holiday check, they pointed out that the diff leaks and that I should book the Disco in to replace the diff. You should have heard them going quiet when I informed them that it is leaking due to their sloppy work and that they'll have to pay for it. to get back to your situation - if i were you i would get LR involved as it is a design/quality fault. also check that there was a recall on all LR models (2005 - 2007) due to a type of coating used on the internals of the diffs. the fact that the RRS use the same/similar drivetrain as the Disco I would take it that it should be covered by that recall. good luck trevor |
Fri Jan 28 2011 12:08pm |
Mixy Member Since: 20 Feb 2012 Location: Cheadle Posts: 39 |
Hi All
Wed Jul 11 2012 5:51pm |
karnic Member Since: 18 Jul 2012 Location: dublin Posts: 3 |
Hi all,
Wed Jul 18 2012 2:36pm |
harbieboy Member Since: 26 Oct 2012 Location: Leicester Posts: 5 |
I have a RRS TDV8 In general I have been very pleased with the vehicle, however over the last few months it has developed a loud whine or hum that rises and falls with speed and which appears to be coming from the differential which is also leaking oil. The vehicle is low mileage (50800).
Mon Nov 03 2014 9:36pm |
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 |
Has anyone got a definitive list of vehicles recalled for front or rear diff problems, and what sort of price should you pay for a recon replacement? Price seems to have jumped from about £350 a few years ago to about £900 now (Front).... |
Mon Nov 03 2014 11:22pm |
