Home > Technical > Temperature Drop Beep
rweintra
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
I was wondering if there was a way to shut off the beep that the RRS makes when the temperature drops to 37 F, which I believe is the point at which the road can freeze? Is that correct? Anyway, is there a way to shut it off? It kinda gets annoying because the temperature right now hovers around there and it goes of all the time.
Post #8859 Sun Dec 25 2005 5:17pm
grommet
United States
Yes, it's an "ice possible" warning. Sorry, no way to disable it. Feedback to LR if you'd like, but it's common on many vehicles.
Post #8863 Sun Dec 25 2005 6:55pm
Re: Temperature Drop Beep
..and you should find it only happens when the temp travels from >37F to <37F - does the temp really fluctuate that much? As with most "warnings" they are difficult if not impossible to turn off. I expect LRNA are quite happy that you can't turn it off, given the litigious nature of your country Wink
Post #8919 Wed Dec 28 2005 12:34pm
