Home > Off Roading > Non-winch Mantec plate for the RRS ???
Rupert
Ireland 2008 Range Rover Sport TDV6 SE Java Black
I’m thinking of to “butching up” the sport a little, as I’m now tired of the “street look”. So the 20” Stormers are coming off again & am currently trying to source a mild, but yet knotty tyre for the 19” rims. But that’s being discussed elsewhere.
I’d also like get an under body plate, but see that on the LR brochure, they only list the plate for use with a winch. I know that Mantec do a non-winch plate for the D3, but can’t seem to get any info on a RRS version.
The Mantec web site is of no use at all
So anyone got any info on the availability of a non-winch plate for the RRS ????
Post #187211 Mon Sep 08 2008 12:50pm
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Rupert - not sure. As far as I know they only do the non-winch but ISTBC. Ring Mantec. WINNER - 2008 Outstanding Contribution
WINNER - 2008 ‘Just Doing What It’s Designed To Do’ Award
Runner Up - 2008 ‘Idler Of The Year’ Award
Post #187213 Mon Sep 08 2008 12:58pm
Tim in Scotland
I assume there must be two versions available from LR as the G4 kit can be bought with or without a winch and there is a bump plate available with the RRS G4 Accessory kit A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #187218 Mon Sep 08 2008 1:16pm
Rupert
RRS G4 Accessory Kit Question
Post #187222 Mon Sep 08 2008 1:22pm
Tim in Scotland
Yep, here on the LR GB Website:
http://www.landrover.com/gb/en/vehicles/ra...llenge.htm
From the webpage
Quote:
The Land Rover G4 Challenge is the ultimate 4x4 global adventure competition. And every Range Rover Sport taking part is equipped with Land Rover G4 Challenge accessories. Each one is designed by Land Rover to add even more capability and versatility to the vehicle and each one can be fitted to your Range Rover Sport, too.
More details are available from your nearest Land Rover Dealer.
Land Rover G4 Challenge approved accessories include:
• Electric Winch
• Front and Rear Lamp Guards
• Expedition Roof Rack
• Cargo Barrier
• Rear Ladder
• Raised Air Intake
• Driving/Fog Lamp Kit
• Body Side Mouldings
• Front and Rear Mudflaps
• Underbody Protection
• Rubber Mats
Post #187224 Mon Sep 08 2008 1:26pm
Rupert
Cheers Tim Thumbs Up
Post #187227 Mon Sep 08 2008 1:33pm
bcp
I have 4 of the black 19" 6 spoke alloys if you are looking for rims.
BCP
Post #187286 Mon Sep 08 2008 9:22pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
Rupert,
I have the LR underbody plate and no winch. Unfortunately, this is one of those LR rumors/mistakes, however, as clearly evident, there are a number of us running the underbody plate without the winch. As far as I can tell, there is only 1 version of the shield from LR...not two, or at least, here in the U.S. that's the case, can't swear for sure for the UK - but it's a moot point anyway.
What you have to be aware of however, is that you do have to do a small bit of cutting of plastic, i.e. the shield that covers the front recovery hook, however, no cutting of the bumper is required. And...the bolts which come with the underbody shield have to be changed a bit to a different length Grade 8 bolt, since obviously you won't have to put the bolt through the winch assembly and then thru the shield, therefore you need shorter bolts.
I've helped a number of the RR.NET owners do the install with pictures, let me know when you are ready and I'll send them over.
Evidence:
 PJPR - 06 Cairns Blue RRS HSE Adventurer
Post #187290 Mon Sep 08 2008 9:54pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Also, I don't know where the intercooler air vent would be on a turbodiesel engine (on the S/C it's be down there behind the LR G4 accessory skid plate), so you may have to modify that plate a bit as well. Here is a rr.net forum member with a S/C and the plate, note the holes drilled on the LH of the plate to allow for airflow to the supercharger:
Post #187298 Mon Sep 08 2008 10:49pm
Rupert
Thanks so much guys for your advice Thumbs Up
I don't mind the cutting aspect of the fit up job. Just one question though........
Is the installation reversible ??
Say for instance whenever I decide to trade the car, will I be able to return it to standard, or will there be evidence of where I cut the plastic ??
Post #187332 Tue Sep 09 2008 9:26am
These sort of cuts are normally one-way... a little bit like fitting the roof bars.
2008 RRSPORT.CO.UK Awards Nearly Man Crying or Very sad
Post #187336 Tue Sep 09 2008 10:27am
Rupert
Yes Shmoogy I'm sure the cuts are indeed one way Wink
What I'm wondering is, are the cuts underneath & hidden away when viewing the car normally & you only see the cuts if you crawl in under.
Or are the cuts in plain view ?
Post #187342 Tue Sep 09 2008 10:53am
PJPR01
As long as the underbody shield is on, you cannot see the cuts unless you peer very closely around the recovery hook. If you are planning on taking the shield off, then the cuts would be visible, but perhaps you could then replace that plastic piece with a new one. PJPR - 06 Cairns Blue RRS HSE Adventurer
Post #187357 Tue Sep 09 2008 1:14pm
Michaels RRS
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Is it not possible to grind off the two plates shown in the photo below, then you would not have to trim the bodywork to fit the guard ? and when it time to sell the RRS, just refit the tow hook cover Very Happy
 Range Rover Sport TDV6 HSE 2007 Commercial
Range Rover Sport TDV8 HSE 2007
Defender 110 Truck Cab 2007
Defender 6x6 Tdi 1989 Dropside(Now Sold)
Post #190722 Sat Oct 04 2008 1:34pm
umbertob
Wouldn't that also weaken the plate in its most vulnerable strike zone, though?
Post #190765 Sat Oct 04 2008 7:30pm
Copyright © 2005-2009 Martin Lewis
