| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Off Roading > Non-winch Mantec plate for the RRS ??? |
| Rupert Joined: 13 Mar 2006 Location: Here !!! Posts: 850
I’m thinking of to “butching up” the sport a little, as I’m now tired of the “street look”. So the 20” Stormers are coming off again & am currently trying to source a mild, but yet knotty tyre for the 19” rims. But that’s being discussed elsewhere.
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15172
Rupert - not sure. As far as I know they only do the non-winch but ISTBC. Ring Mantec. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
RRS G4 Accessory Kit |
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 8082
Yep, here on the LR GB Website:
Cheers Tim |
| bcp Joined: 11 Oct 2005 Location: East of Scotland Posts: 40 |
I have 4 of the black 19" 6 spoke alloys if you are looking for rims.
| PJPR01 Joined: 12 Mar 2006 Location: Houston, Texas Posts: 135
Rupert,
| umbertob Joined: 22 Sep 2005 Location: Pasadena, CA Posts: 739
Also, I don't know where the intercooler air vent would be on a turbodiesel engine (on the S/C it's be down there behind the LR G4 accessory skid plate), so you may have to modify that plate a bit as well. Here is a rr.net forum member with a S/C and the plate, note the holes drilled on the LH of the plate to allow for airflow to the supercharger:
Thanks so much guys for your advice |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20671
These sort of cuts are normally one-way... a little bit like fitting the roof bars. |
Yes Shmoogy I'm sure the cuts are indeed one way |
As long as the underbody shield is on, you cannot see the cuts unless you peer very closely around the recovery hook. If you are planning on taking the shield off, then the cuts would be visible, but perhaps you could then replace that plastic piece with a new one. PJPR - 06 Cairns Blue RRS HSE Adventurer
| Michaels RRS Joined: 02 Mar 2007 Location: North Yorkshire Posts: 56
Is it not possible to grind off the two plates shown in the photo below, then you would not have to trim the bodywork to fit the guard ? and when it time to sell the RRS, just refit the tow hook cover |
| All times are GMT |
Staying - Epsom Green Defender 90 for playing off road
